Where’s the best place to find these resistors? They are 0603 resistors correct?
I’d like to join the question…
Woo Hoo, i just fitted a E2 3C led to my UT02 / 5 tail amps, looks real sweeet now
dave
did u get your from cutters.com.au?
yep on a board , swapped out the led only, thought id practice on the UT02 first before i do the MF02
so they have genuine E2 3C?
few members here have question about them
u bought some, what do u reckon ? they look ok 2 me
got my order yesterday but yet to test them out.
will do lux reading this weekend. Im expecting higher lux reading than stock LED from MF02
is your UT02 NW or CW ? and hav u modded the resistor yet ? how many amps at tail ?
mine was NW and that was considerably cooler than the MF02 in NW . the MF02 seems more like 4000 so it will def get a E2 3C
pls post your before and after figures when youv checked them
cheers Dave
i have UT02 NW and CW
as well as two Astrolux MF 02 throwers
will swap them all and check the lux ready this weekend
So not modded then ?
which tint did u prefer in the UT02 ?
Anyone with tips on how to MOD to make UT02 much better thrower along with great spill? The light is thrower but to make it ultra thrower with excellent spill???
Just search UT02 resistor mod on this forum , there’s plenty info on getting it to draw 5amps at tail end she’s a good thrower then , nearly as good as a Klarus G35
Wait for Schoki+Lexel’s boost driver to be released. It’s capable of pulling 19A from the battery. That means you can drive XHP35 to any current you want. Mild 2.3A (8A from fresh battery) or wild 3A (11A from fresh battery) - the limit is what you want.
Do note that it won’t be able to sustain the output due to thermal limitations.
And that it’s going to cost way more than a resistor.
Any news on the boost driver?
My UT02 is kaput, so I have ordered a xp-l Hi v3 and a fet+1 driver.
Can I keep the existing switch? (have ordered a c8 switch just in case).
Was planning to strip existing driver (except spring and outer -ve pole) and wire the fet driver to it.
I have never modded a light before, so can someone please help me with advise and procedure?
Thanking you in advance.
