do not forget to participate on banggoods giveaway
Ordered a Folomov 18650S with your link and code. Thanks Martin.
:beer:
Hello my dear friends!
new deals for members: M4D M4X deals
Weltool W3
400-700nm Custom LEP Module
2Modes IP67 Waterproof Tactical Flashlight
Sofirn C8F
21700 Version
3x XPL 3500LM
4 Mode Groups
Triple Reflector LED Flashlight
Sofirn SP32A
XP-L2 V6 1550Lumens
High Power 2 Mode Groups
EDC FlashLight
M4D M4X I saw this and thought of you:
Thats a SP32A with a silver button.
For information, there is a newer one:
SP32A v2.0 with a black button and a center LED in the button.
I have only the v2 and recommend that light a lot.
What I know from reviews the silver button version is not so nice: Weaker ramping, led tells the voltage
Fireflies E07 ready to order @nealsgadgets
Neal listed the new:
FIREFLIES E07
7X SST20/NICHIA/XPL HI
up to 6900LM
21700 FLASHLIGHT WITH ANDURIL UI
preorder with my code: NDFFE07 to sweeten the deal (do not post the price ;) )
please click my shoplink
Matt Black arrives this week
Gun Grey arrives December 10
Desert Yellow arrives December 15
Clear Anno arrives December 25
Version type:
- 7x Nichia 219B R9080 CRI98
- 7x SST20 4000K NW CRI95
- 7x SST20 5000K NW
- 7x SST20 6500K CW CRI66
- 7x CREE XPL HI V3 CW 6500K Max 6900 lm
- 7x CREE XPL HI V2 NW 5000K
Product Description:
- Made of 6063 aluminum alloy and 304 stainless steel
- Body color: Matt Black , Gun Grey and Desert Yellow
- HAIII Anodising Surface Finish
- 1x 21700 / 18650
- 25 degree angle TRI lens
- 98% AR coating glass lens
- Digital current regulation on lower brightness
- IPX6 waterproof
- with Aux leds ; with switch leds
- Size: 112mm(L )x 37.5mm(Head) x 26mm(Body)
- Net Weight: 125 gram
Accessories: standby O rings ; Stainless Steel clip; Landyard; Gift box
Is the driver glued in E07?
I wish they said the lumens for each type of emitter. It can’t be 6900 lm for all of them.
I can’t tell if the switch has leds or not.
Martin, it says code not valid for the E07
fixed the code typo
sorry
we ask to get the lumens for each led if possible
(they just promote "up to" )
+Any other color of Aux light the one shown is ![]()
edit: just see Aux light option
I just saw these specs:
7x SST20 4000K NW CRI95 3500lm
7x SST20 5000K NW 3500lm
7x SST20 6500K CW CRI66 4500lm
7x CREE XPL HI V3 CW 6500K 6900 lm
7x CREE XPL HI V2 NW 5000K 6200lm
The SST20 leds are not near the HI power, but I wonder if it’s a moot point. 6000+ lumens in a light this size is most likely going to step down pretty quickly.
I have no experience of the SST20, can someone please give a quick rundown of pros & cons compared with the other LED options?
We should probably direct all E07 questions to the E07 thread.
18650 adapter is included @ E07
I noticed that the E07 Aux LED options are different on Nealsgadgets vs Fireflies own website…
ff-light:
Purple Aux LEDS
Ice Blue Aux LEDS
Purple + Ice blue
Nealsgadgets:
Blue
Purple
Yellow
Red
Order placed for one grey Nichia with red aux LEDs, thanks again M4DM4X
if you check my member deals list (M4D M4X deals) you find:
NITECORE MH40GTR
XP-L HI V3 1200LM
6 Modes Tactical Tail Switch
Kit with 2pcs 18650 Battery
Features:
– Maximum peak beam intensity of 252000 cd and maximum throw of 1004 meters.
– Intelligent charging circuit with voltage detection charges safely and rapidly.
– High efficiency constant circuit provides stable output up to 140 hours.
– Onboard charging port sleeve protects the port from dust and water ingrssion.
– Four easily accessible brightness levels.
– User defined mode allow for quick access to the setting last used.
– Intelligent memory function stores preferred brightness settings.
– Broad voltage circuit accepts both rechargeable and non-rechargeable Lithium batteries.
– Electronic reverse polarity protection.
– Toughened ultra-clear mineral glass with anti-reflective coating.
– Constructed from aero grade aluminum alloy.
– HA Ⅲ military grade hard-anodized finish.
– Waterproof in accordance with IPX8 (2 meters submersible)
– Impact resistant to 1 meter.
– Stainless steel titanium-plated clip.
– Anti-rolling design.
Package included:
1 x NITECORE MH40GTR LED Flashlight
2 x NITECORE NL1835HP 18650 3500mAh Rechargeable Li-ion Batteries
1 x EU Wall Charger
1 x Spare Switch Cap
1 x Clip
1 x Tactical Ring
1 x Lanyard
1 x Spare O-ring
1 x Instruction Manual
1 x Warranty Card
and those deals are lowered A LOT:
| klarus | XT11GT Camo |
| haikelite | MT03 TA |
| Imalent | DX80 |
| IMALENT | MS12 |
| Imalent | RT35 WITH BATTERY |
| IMALENT | HR20 |
| Klarus | XT12GT |
| Wuben | A21 CW |
Man that Nitecore MH40GTR looks like a sweet host for the Oslon White Flat. Too bad they use a proprietary charging port instead of USB ![]()
