“populated” when referring to a charger is used to talk about the number of spots used up by cells.
As you can see in the above image, neither of the two spots are populated.
That’s what people mean when they say a charger is not “populated”, although this may not be obvious to people who’s first language isn’t English.
Those are nice PCBs, even if they aren’t fully populated yet
All my stuff happens on prototyping boards. I should try a custom PCB service sometime; judging by the work I see here on BLF, it seems like an interesting learning experience.
I want 10 bay charger, but too cheap. I was eyeing some DigiKey cccv. Can easily make the 18650 taco holders. Then need to find a ac DC transformer. . Too scared I may be missing some safety. Would like a momentary volt readout button. Maybe one meter connected in parallel to all bays. . Press momentary on switch per bay to get readout while charger switched off.
I can see one potential safety issue there: what happens if someone presses two of the momentary meter reading switches at once? If the cells they’re connecting are in substantially different states of charge, a large current will flow.
May I suggest a rotary switch to select the cell you want a reading for, with a single momentary switch to activate the meter?
That looks really nice. I have charged my Panasonic batteries HARD a couple of times. Stupidly needing cells before rushing out the house so I just dumped two in each Opus and charged them both at 2A per cell.
They didnt get too hot but I appreciate it probably wasnt best for the cells.
A couple hard 2 amp charges on those cells will make littlebto no difference in total lifetime. Its when you charge it daily above 1 amp. The newer cells can handle the higher current much much better. Any 10+ amp cell can be charged 2+ amps. It will still shorten its life some but can be done much easier then on these old high capacity cells. Its old technology. The new imr cells designed for powertool packs hg2/30q etc have a max charge rate of 4 Amps. Construction workers need a pack charged in a hour. Time is money But then at 4 amps charge 20amp discharge you only get 250 cycles and the cells are toast around 2000mah. When a battery reaches 70% capacity manufacturers consider it dead/done. The vtc5a had a max charge rate of 6 amps
Slot 1 - CV 4.14X Volt
Slot 2 - CV 4.19X Volt
Slot 3 - CV 4.20X Volt
Slor 4 - CV 4.20X Volt
Output current is varies about 1.54 - 1.58A
Yes, slot 1 is to low for me. But i’m to lazy change the controller
Since my application was 3 + 1 battery. 3pcs for K40M and 1pcs for L2, so i will leave it as is
Thanks for reading my post
This looks extremely interesting and I’m curious how versatile the controller is.
You mentioned a “TP5100” controller chip, do you have a link to a datasheet? I somehow only get obscure links via google…
Thanks a lot.
@HarleyQuin - I should show’s at top of the searching result “TP5100” with google. Yes a Chinese datasheet
I can not read Chinese but motsly it’s about the same as TP5000 datasheet with different pinout, voltage, battery config.
@Lexel - IIRC, In datasheet i could not find a way to adjust the “Constant Voltage” value.
@degarb - about $50ish for 2 set. This is not include parts that i already have like inductor, resistor, capacitor, etc
