Looks good, nice job :)
Really a good job. The only problems could be the heat transfer at full power.
Bravo stari!
I knew you'll end up doing it nicely. How's the XM-L tint? I have not tried yet mine. Only the ones form LEDDNA... yellowish to green tint.
Tint is very nice white imho near 6000k - comparison:
first skyray s-a1, second modded tr-801, third c30 (with P4 led):
No color tendency of the corona of any kind?
There's actually a forum devoted to laser pointers?
Foy
???! Yep there is... http://laserpointerforums.com/
There's a lot of action over there. Over 4,000 active viewers? I would have imagined.
mustgetoutmoreFoy
You need a spacer at the led or a o-ring at the lense to do away the donut-hole
Thanx. Didnt know that! I will fix it...
After receiving so many led emitters, I had to do another mod. This time the smallest 14500 light - and this one is really small at just 57mm (for comparison - well known one of the smallest AA/14500 lights tank007 e07 is 87mm long ). It has no reflector though. Reflector will be optional add-on/slide on (when I find a sutable one)... Powered by a 14500 and using QTC as current regulator, the osram led puts out more than 150 lumens (14500 in DD - a little overdriven ) . Its a twisty (no switch), actually the body is well known BLF delighft cut almost in half, copper coin in the end of tailcap. The 16mm led star is mounted direcly (very tight fit - I had to sand it down a litttle) in the tube. Works really nicely with QTC, those osrams are pretty bright. My craftmenship and finish arent really up to the "Match" standard. That guy really knows what he is doing, he could easly sell his DIY lights for muchos dinaros to some CPF snobs
Hey UDO is it possible if you can please take pics of the light broken down. Is this still configured like you stated in the beginning of the post?(led/aluminum heatsink coin/battery/QTC)(no driver)
It still has no driver, only QTC limits the current. Great for brightness, but 2 days ago I had it on full brightness for more than 20 minutes ( I had to take 200 pics of pages in some book - I used flashlight instead of flash) and it was getting reaaally hot - I would say near 70 degrees C. So you have to be carefull not to use it on full power for too long...
QTC is getting tired, but I found a way how to push battery without spining it (no twist action is getting on to QTC). Also Im waiting for 60 degree lens from DX to replace the reflector.
Thanks UDO!
how about foam and qtc and two round plates/coins. encase the sandwich in something flexible(rubber heat shrink or dip it in that rubber insulator compound used to insulate plier handles or screwdrivers) so its held in place with no rotation between the plates. im probably overthinking this but you get the idea.
when i get a qtc i want to try it on the solarforce single mode dropin i have. good luck!
Who sells QTC material?
