Measuring impedance
Well gentlemen, let´s dive little bit deeper into the ocean of resistance measurements of the Li-ion cells.
I agree that different methods can give different results. So it is important to have the same measurement methods. I also agree that DCIR is more relevant, for various reasons.
ACIR 1 kHz (also called impedance) measurement is usually no problem as there is lot of dedicated equipment like SM8124A, YR1030, or YR1035 which are not expensive and are easily accessible and accurate enough.
Situation with DCIR measurement is different, people usually don´t use unified method, some even don´t distinguish between ACIR 1 kHz and DCIR.
I measure DCIR according INTERNATIONAL STANDARD IEC 61960-3:2017, paragraph 7.7.3 "Measurement of the internal DC resistance".
Full name of this standard : Secondary cells and batteries containing alkaline or other non-acid electrolytes – Secondary lithium cells and batteries for portable applications – Part 3 : Prismatic and cylindrical lithium secondary cells, and batteries made from them
Frankly, I haven´t found more suitable standard for Li-ion cells measurements than IEC 61960-3.
Description of the DCIR measurement :
7.7.3.1 Measurement
The battery shall be discharged at a constant current of I1 = 0,2 It A. At the end of a discharge period of 10 s ± 0,1 s, the discharge voltage U1 under load shall be measured and recorded. The discharge current shall then be immediately increased to a value of I2 = 1,0 It A and the corresponding discharge voltage U2 measured under load and recorded again at the end of a discharge period of 1 s ± 0,1 s.
All voltage measurements shall be made at the terminals of the battery independently of the contacts used to carry current.
The internal DC resistance, RDC, of the battery shall be calculated using the following formula :
RDC = U1 – U2 / I2 – I1 (Ohm)
Where I1 , I2 are the constant discharge currents U1 , U2 are the appropriate voltages measured during discharge.
Actual measurement was done in 3 consecutive pulses with 30 s pause for cell cooling down :
Voltage drop measured at the cell :
Samsung 35E DCIR is 30,1 miliohm at 3,82 V and ambient temperature 25 ± 1°C. ACIR at the same conditions is 20,3 miliohm (measured with YR 1030)
Equipment : DC electronic load Maynuo M9712, DMM GW Instek GDM-8351, 4-wires testing fixture BF-2A, thermometer Omega HH520 with K thermocouple.
DCIR of the cell is changing through SOC course, especially at low SOC, therefore it´s important to mention the voltage in the protocol. DCIR is temperature sensitive, so ambient temperature reading is also important to display.
True 4-wire measurement is must for both ACIR and DCIR measurement.
Bellow you can compare HKJ´s values with results measured according IEC 61960-3 standard :
