1xAAA / 10440 will hang on a keychain unobtrusively
1xAA / 15400 is pants-pocketable¹ to the point that it doesn’t seem to require any real thought nor negotiation
1x18650 with a low overall profile is at about the limit of pants-pocketable¹ - can slide it in there but it’s a tad obtrusive and jostles against the other contents ¹ front men’s trousers/jeans pockets; can’t speak to other genres
Don’t have any low-profile 21700 lights. Suspect that the D4K might push my concept of the limits of what I can put into a pants pocket being nominally another 3mm in diameter and 5mm longer.
Like the DM1.12 it could be slipped into a holster, but that’s apt to attract a tad bit of attention from randos when perusing the merchandise at the local megalomart. Unless of course it happens to blend in with the rest of the tool/duty belt.
Agreed. Besides low (battery) capacity they usually offer low sustained lumens and candelas.
That’s why I EDC a TS10 as my main light, but an FC13 too as backup light: besides also working as main powerbank, it’s ready to take over in case I need more lumens or more reach, or if something happens to the TS10.
with 16340 being a close second
I confess I never quite saw the point of 16340 batteries. OK, they are a bit shorter, but the ones I can find are usually even lower-capacity than 14500s, and the TS10 is already more than short enough for me.
The Olight S-Mini is the point of 16340 batteries. It’s the only 16340 light I’ve used which seemed worthwhile, and it hasn’t been produced for quite a while, but perhaps someone might build a modern take on it.
I’ve just tried mouthing the MF01. It’s possible for a short period pointed downwards but any slight jerk will result in bleeding and/ or lower tooth count and/ or crushed toes.
Several times a day. There’s a perfectly good DW4 with a Fenix strap in the backpack just metres away almost every time and I’ll still mouth the torch that’s on me.
I think they usually use PIC MCUs, same for a lot of flashlight manufacturers actually, the Thrunite, Acebeam, non Anduril Sofirn and Wurkkos I disassembled used PICs. edit : and Zebralight
