Bits of code can be disabled by being “commented out”.
In C (and recent versions of C) this means putting two slashes at the front of the line, or surrounding a block with a slash and star:
This line is normal.
// This line is commented out.
This section
is commented out.
In the above, only the “normal” line will have any effect. The others are basically turned off so they will be ignored. It’s an easy way to enable or disable pieces of code without actually deleting them.
They call it commenting or uncommenting because the slashes convert the text between active code and a “comment” (typically used to explain what the code is doing).
No need to use this limited one if you only want to set a few modes and be done with it. I wrote a simple firmware that you don’t need to know how to code to use.
Just set your modes and flash, no explanation needed.
Hi guardior. Thanks for tuning in.
The thing I want is a 4/5 mode driver, that will always start from Low when powered off.
But has to move to the next mode while in use.
I dont need any strobes etc.. Thats why I like the minidrv. Yours seem to have strobe, beacon etc.
Edit: My firmware doesn’t got off-time so if you want that too you have to look elsewhere. I didn’t even know what off-time was until ToyKeeper explained it in this thread. I don’t think I like off-time anyway so probably would never implement it.
