rpscuba
(rpscuba)
July 19, 2017, 1:50am
21
So I see that I need a little education on drivers. What are the different ones, I see “direct driver” and “constant current” are a couple of options… Any rules of thumb on chosing them?
Also, any pros/cons with led’s in series or parallel?
Thanks again.
MRsDNF
(MRsDNF)
July 19, 2017, 3:02am
22
rpscuba:
Thanks again.
This may explain a little. Direct drive (DD) means that the driver will give the led everything the battery has to offer without being regulated.
A long time ago I promised I would do a topic to explain to the interested layman the difference between Linear, Buck, Boost and Direct Drive drivers. Well, here it is.
Direct Drive
[image]
This is the simplest and cheapest design. As its name implies, it is a direct path to the LED, just like old incandescent flashlights. Sometimes there is a control chip and transistor to create modes (High, Low, Strobe, etc.) by rapidly switching ON and OFF the LED. That’s called PWM.
This is used by peop…
rpscuba
(rpscuba)
July 19, 2017, 3:09am
23
MRsDNF:
rpscuba:
Thanks again.
Understanding the difference between Linear, Buck, Boost and Direct Drive drivers
Very nice, thanks for the link - reading it now.
rpscuba
(rpscuba)
July 19, 2017, 9:57pm
24
What are some of the better CC drivers that are commercially aviable? I want to order all of the components in the next day or so… looking forward to building my first light.
Thanks
2S cells with 5P or 5S emitters? DD doesn't seem a solution unless 5P and he goes 1S cells.
