I want to drive two XM-L's somewhere between 2A to 3A each (was expecting them to be in parallel with two separate drivers) for respectable output (meaning if someone sees my lawnmower coming their way in the dark they will "respect" me and get the heck out of my way! :) ).
To drive 3 xml’s (in series) at 3 amps, you would need one of the following regulators with a .42 ohm resister connected to the center tab. Then the resistor and the left tab (your left looking at it) would to the + of your leds. The right tab would be connected to the + of your battery (or whatever). The - of your leds would connect to the battery.
The resister would need to be rated for a min of 3.75 watts. Use 5 2ohm resisters connected in parallel to get to .4ohms.
EDIT: If you use 5 1watt rated resisters, that would give you 5watt capacity. The watts are so low because only 1.25 volts is being applied across it.
EDIT2: You could have a switch to cut out 3 of the 5 resistors. When the switch is off, you would be driving the xml’s as 1.25 amps. Which would still be about as bright as a TR-3T6 on high.
1. you can leave the stock wiring unaltered, so that you can revert to stock. that way, even if the thing is ragged when you sell it, you can recover your leds and driver w/o rendering the tractor useless except daytime.
2. i’m an electronics dummy…and won’t want to figure out how to make any other solution work
Also, I’d probably consider xml ezwht - since I know there are 12V/1A LED drivers - I forget their max current, but I’m sure you could do 2 x 6V in series with one driver, and probably get away with 2 x 12V with 2 drivers if you use sinkpads and good heatsink
Connect AC from the mower to a bridge rectifier with a filter cap (say 2200 uF) on the output and feed that to the driver. Drive 3 XML’s in series… maybe 4…
That does sound like a nice option. Not sure how I'd mount it. Guess I can use it to drive two XM-L's in series? And with this would I even need to use my drivers? Would using the drivers add a layer of protection? Connect both drivers in parallel from its output?
Any ideas of this AC/DC to DC voltage regulator I found? It's rated 2.2A max (varies based on input/output voltage apparently), but I don't know what the max output would be with 18v AC input and +/-5v output. I really like that it incorporates a bridge rectifier onboard. I don't like the big potentiometer that could get knocked after I set the output voltage to what I want.
This module would also let me use the existing 18v AC wiring at the existing headlight connector.
Out of curiosity. If you ever get a chance and feel so inclined, please measure the voltage at your battery while the motor is running (say mid throttle). That may be hard to do though if you have the battery under the seat and a seat safety switch.
That's not a problem at all; the safety switch (i.e. "dummy switch") has been disabled. I actually didn't do it on purpose; the wires fell off and I just left it that way! Not sure when I can get around to doing this though.
The poor lm2596 will very likely die an unpleasent death on that PCB if one actually pushes 3A trough there.
One could desolder it and mount it on a proper heatsink tho.
