Using something inexpensive doesn't matter if it has bad quality. Moreover, there are a lot of good led flashlights that aren't too expensive and do a great job. You can try these led flashlights, I ordered one for myself a while ago, and I was impressed by all the functions they have for their prices. If you check their link on amazon, you'll find a lot of pluses and realize how effective they are. One aspect that I love the most is their battery life. I use my led flashlight for over 6 hours a day, and I always have some battery life when I get home.
You need a super-long handlebar so you can also mount 5 amber running lights, of the type one sees atop cabs of large trucks. :laughing: And get an air horn! :sunglasses:
this type of mount (swivel in the middle) are all the same - that have a nut and bolt holding the two parts together. You can adjust how loose or tight you want it. Personally I’d use some threadlocker, set it up then tighten it up. No need to have it adjustable unless you’re using it on different bikes and the angle needs to be different for each one. The bolt and nut are recessed though, so shouldn’t come looser anyway.
Incidentally, my mounts have arrived. They are actually really good and work great with my sofirn C8L. They are cheap, come under many different brand names and prices, but I think they are mostly all the same. I bought mine from amazon
OLIGHT FB-1 Universal Flashlight Bike Mount for Flashlight
Application: Compatible with bicycle handlebars and flashlights with a diameter range of 10-35 mm; Compatible with all forward and angle-head flashlights
Material: Made from high strength temperature and impact resistant polymer, the FB-1 is the perfect piece of equipment for any night time bike rider
Compact Size: Low profile height 39 mm to stay out of the way during rides
Qiuckly Attach/Release: Install and detach in seconds with the thick silicone gel rings that form to your flashlights
Package Included : 1 x Mount 2x Larger Holder Ring 2x Small Holder Ring 1x Head Screwdriver
