I did some tests once with batteries that came of at around 4.2v versus 4.17v (Nitecore I2 and Opus 3100 respectively) and from memory the difference was about 1.8% when I discharged them on my Accucel 6. Wouldn’t be useful or noticeable in real life usage for me.
I have created a setting for my MC3000, with termination at 4.25V and 50mA, newer batteries come out at 4.20V, and drops to ~4.17V a couple hours later. But I don’t think there is any real benefit by doing so other than pleasing the absurd need of achieving exactly 4.20V.
As always, thanks for your posts. They are really interesting.
Keeping in mind the information shown on this post, and the information shown on this old post, ( Charger settings ), are these sentences right?
Please confirm them for clarity sake.
1) Charging Li-ion cells to 4,1V means cells will have more lifetime, but less energy.
2) Charging Li-ion cells to 4,25V means cells will have less lifetime, but more energy.
3) Termination current high will make voltage drop after termination high.
4) Termination current low will make voltage drop after termination low.
5) Charging a cell to 4,2V with low current termination will give more performance than charging the same cell to 4,2V with high current termination.
6) The best possible charge to obtain maximum performance from a Li-ion cell is to charge it to 4,25V, and a very low termination current. (Forget about cell lifetime).
And some questions:
It is really interesting to go to 0,025A termination current, or even lower in big capacity cells (forget about charge times) or it doesn´t worth it?
Do you recomend to modify termination current setting, depending on the capacity of the cell?
Answer: to obtain maximum performance. I know doing this will cause shorter lifetime, but performance is performance.
Why drag race cars engines have this setup? For maximum performance. It doesn´t matter if it lasts for 2 or 4 miles, the most important is to perform as better as possible in the first mile and win the competition.
Answer2: don´t worry, I won´t charge my batteries to 4,25V. I preffer to extend their lifetime.
I sometimes wonder about 4.35v batteries. How much is that ACTUALLY a superior/different chemistry, and how much is ‘hot rodding’ the battery at the expense of shortening it’s life?
The termination current of the CV-phase of Li-Ion battery charging algorithm, also of NiZn. When
reaching TARGET VOLT, e.g. 4.20V, this option will hold the voltage constant while automatically
reducing the current down to the specified value before it terminates the charging routine. A high
termination current serves battery health but will not charge the full battery capacity. The
parameter defaults to 10% of C.CURRENT, an industrial standard. “Zero” means an ever
decreasing charging current: not good for your patience or battery but allows to produce quasiconstant
4.200V battery voltage if that’s what you’re after. OFF means no CV-phase once the
target voltage has been reached.
That means high termination current is good for batteries lifetime?
The manufacturer do often include a termination current in the datasheet. A lower termination current will charge the cell to a higher voltage and stress it a bit more.
With smaller cells it is often necessary to reduce the termination current to get a full charge, in the hobby charger world the standard is 1/10 of the charge current.
When you say: ” A lower termination current will charge the cell to a higher voltage and stress it a bit more.” I don´t understand at all this sentence. Maybe it is wrong?
For me it is clear now that low termination current stresses the cells a little bit more than higher termination currents.
But I understood the voltage only increases during the CC phase, and would be always the same (constant voltage) when the CV phase starts. The charge intensity (amps) decreases during this CV phase. Depending on how high the termination current is, the voltage drop will be higher when the charge ends.
In fact, you say in the original post “In the CV phase the charger will hold stable 4.20 volt and the current will drop until it is down to the cutoff value.”
So… I am lost. Sorry, my english is not very good, and maybe I am not understanding you properly. I only want to understand all the theory behind this process.
During the CV phase, the bigger the difference in voltage between cell and charger, the higher the current flow.The charger will keep pumping 4.20 volts while the cell is not at that voltage yet. If they were equal, there would be zero current flowing. That’s why charge termination current is meaningful. The higher termination current means the cell is still that much lower voltage than 4.20 volts.
I think I get it. Thank you both for the explanation.
In the table of http://lygte-info.dk/info/BatteryChargeVoltageCurrent%20UK.html seems it is better for cell performance to charge to 4.15V with termination current of 0.050A (Energy = 95), than charging to 4.20V with a termination current of 0.400A (Energy=93).
I assume this setting (4.15V, termination 0.050A) is also better for cell lifetime, right? (The only “problem” in this case will be the time you need to finish the charge of the battery).
Would it be possible to charge with 1.5A (or more) during the CC phase to 4.18V-4.19V, and then set up a termination current of 0.025A (or less) on the CV phase?
What I am trying to find is the best performance/cell lifetime/charge time ratio.
