Need help finding hand held hunting light
A c8 is a small (6” x 1 3/4”) reflectored light, and my personal favorite form factor, I like a light to look mag esque ie head and body.
Here’s the link to arguably the best c8, they can be had for a lot cheaper or built.
http://www.intl-outdoor.com/xintd-c8-v3-xml-u2-xml-u3-flashlight-p-308.html
The kaidomain c8 springs to mind as another favorite, you can also get pressure switches for them if you wish to gun mount.
It’s close on a 1000 lumen depending on exact spec, I’d guess the one I just assembled (c8 upgrade host from Cngq, xm-l u3 2.8a driver) at 700 - 800 lumen, they are a very nice little light that handle heat well, just you’ll need a couple of cells for a couple of hours on high.
The one I’ve built will be getting a new neutral white xm-l2 when it arrives along with a slightly higher output driver.
They are a very good choice if you go with one of the ones reviewed on here for example.
This is the keygos m10, my personal favorite of the c8 sized lights.
They are all reflectored though and not zoom models, you get some flood and some throw, but they are a solid light choice.
