Since we're talking custom UI's, I've just cooked myself a more.. sensible UI for an EDC, unlike for a Hot-Rod.. It's Anduril 2 basically with my own touch, what I've found to be more appropriate for an all around light..
Hex files for D4V2 and D4SV2 (XP-L & XP-G2/219C) are included along with the sources.
80T's Custom Anduril 2 Mod (based on Rev. 583)
- 5 Lvl. Moon (memory)
- Max brightness is - Max_Nx7135 (smooth ramp)
- 1H (from Off) - Moon (one of the 5 discrete lvls. as it has memory) -> Keep Holding until blip > Beacon </> S.O.S. / (from On) - Ramp Up - Release and hold again to change direction / (from lock) - Temp Moon (mem)
- 1C (from Off) - On (memory - smooth/default ramp) / (from On) - Off/Back (from Turbo) - If Turbo was from the Off state, 1C will still return to Off
- 2C (from On/Off) - Max Lvl. (only from normal smooth ramp mode) / (from Beacon/S.O.S./Batt Chk/Temp Chk/Candle/Lightning Storm/Bike) - advance/cycle to the next mode
- 2H (from Off) - Momentary Ceil. / (from On) - Ramp Down..
- 3C (from On) - toggles between Discrete/Smooth ramping styles, only now discrete is 5 lvl. Moon and smooth is the actual standard illumination mode / (from Off) - Batt Chk. </> Temp Chk.
- 3H (from Off) - Fun blinky modes - Candle > Bike > Lightning Storm > repeat / (From On) - Momentary Turbo
- 4C (from On/Off) - Lock / (from Lock) - Unlock to Off
- 4H (from Lock) - Moon (mem)
- 5C (from Lock) - Unlock to On (mem)
- 5H (from On) - Configure Sunset mode
- 7C/7H (From Off/Lock) - Config AUX LED's - Style and Lvl.
- 10H (from Lock) - Config Auto-Lock
That's pretty much most of what I've changed/rearranged.. Also small little setting changes like not having the LED's turning On at all until the clicks sequence is done (2C, 3C etc.. ) Beacon Lvl. at Max Lvl. and very short pulse (10ms) like most Nicore lights, no manual memory, no advanced/simple UI (I'd say this is a decent mix of both.. ), the AUX LED's are Off by default (but set to Voltage display - Where the colors are Green > Yellow > Red) and whatever else skips my mind right now..
Oh yeah and.. there MIGHT be any number of leftover unsquashed bugs present.. (that I have not yet encountered that is anyways.. )
I would love to have this kind of light with a proper efficient Buck driver.. :(
Cheers!
EDIT: Well, it was bound for me to find some bugs.. (sometimes while changing ramp styles and tried to ramp immediately, the ramp direction would not be properly reset.. ) and to squash them ofc.. New version uploaded
Also reverted 2H back to ramp down as it seemed to have more utility than Temporary Ceil..
