Why does the switch have to be so far deep into the tail cap? I find it more difficult to turn light on and off. It’s almost like you have to use the tip of your thumb,rather than the meaty part.
I wish they would raise the switch. Still lots of room and still be able to tail stand.
I have no problem pressing the button on mine with the meaty part of my thumb. I dont have a depth guage, but it looks like the highest point of the swtich cover sits about a 1/32 of an inch below the rim of the tailcap , at least on mine.
My Clear C8 tail cap is such that I can use the joint of my thumb to activate the switch, no problem using the thumb tip either way.
I just ran through some settings changes and mine works nice and smooth, not fast, not slow, plenty of time to make a selection without being excessive either way. I have last mode memory engaged, works fine, presently using level 2 for the moon mode with 4 more higher levels.
I stacked an extra 6 7135 chips previously, so it’s running very nice now.
I programmed mine once without memory or flashy modes. So far it’s been working great. Basically it’s set and forget. No plans on changing the program.
I will say I like the style of switch boot the astrolux lights use that have a “taller center” section that sticks up a bit compared to the edge of the boot. It seems easier to press in the lights I have it in. Although I like the total size of the convoy boot better (16mm vs 14mm?).
Sorry, I’am a newbie. Can anybody tell me how can I get 15% off for this C8? I click on the link in the first post but cannot see anywhere to pun 15% off code, and who is Simon so I can send him a message?
Well I thought you are supposed to enter/submit your order, but don't do the last step of paying for it. In the order, add the message to Simon - there should be a place to enter it, and ask for the BLF 15% discount. He then updates the order with the discount, then you pay.
Might take a day or two for him to apply the discount - think you will get an AliExpress notification.
As much as I like to support Simon, when he didn’t respond to me after 4 days for the 15% discount, I canceled my order and ended up ordering one from Fasttech for around the same discounted price. I received it in 15 days. Happy to say, it’s the latest version. That being said, I’ve ordered and received several items from Simon with no problems getting the BLF discount. He must have been away?
Quick question… are Convoy C8s from GB (or FT) considered “real” C8s, as in the same innards you’d get directly from Simon? (It’s basically my first store-bought C8 that I’m not going to strip down to pieces and pretty much just reuse as a host.)
I got one from GB, nice NW XP-L HI, nice’n’bright, totally happy about it, well, almost totally. Comes with all the damned blinkies enabled, and it seems the necessary time to get a mode-change to “stick” at first had me worrying that it had next-mode memory. I had to really wait, and still ain’t sure if it needs N sec on-time, or off-time, to get the change to stick. Basically, it doesn’t seem to act the same way pretty much all my other reverse-clickies work. Tap, tap, tap, off, and that last mode sticks. Here, it’s like it almost jumps to the next mode unless I wait loooong enough for the mode I want to stick. Also concerns me that a quick burst of light will also cause a mode-change when I don’t want it.
I know… moan moan moan… but I’m curious if “real” C8s act that way. Just seems… odd.
There are some potential issues with the new layout of the new style driver. Tom E has found that pin 5 of the MCU is connected to the ground pin of the 7135 and this is interfering with some timing control. I had re-flashed my MCU with firmware direct from ToyKeeper and while it was somewhat better due to the proper fuses being used in the flash code, it still wasn’t perfect. I then found out about Tom’s findings and opened my Clear C8 back up, sliced (carefully) that trace to eliminate ground to pin 5, and now it works perfectly.
You might want to look at this Y shaped trace coming from pin 5 and address this issue, see what that does for your lights operation.
Edit: For confirmation, this is on the new red board with Bistro Mini (or Biscotti as it’s being called)
Edit II: This information is being looked at by Simon and his people, the holidays are probably going to slow down any response, but corrections, if found necessary, will be made as soon as possible by Convoy.
I think the Clear C8 from GB and BG have the old/traditional Convoy firmware, which isn’t surprising given the overclocking issue with the new firmware.
Green, with an all-lowercase “convoy” printed on it.
Oh, bugger. Are there any stars/jumpers/traces/anything to get rid of the damned blinkies, or should I just throw in a 105C and be done with it? I bought the beastie just so I wouldn’t have to do anything like this, and…
I’m okay with 1-mode, so I might just hardwire the damned enables on the 7135s to do just that. Just charging a 30Q to go into it, might have to use a protected panny-B instead, then (no LVP anymore if I do the hardwiring).
Doubt it (green board). Unless that comes with blinkies enabled by default, too. Haven’t tried diddling with the switch to try to get into mode-selection, if all bistroed out.
Bah. I think I might just have to go to hardwired 1-mode to fix, well, everything.
It’s a black one, think it was one of GB’s flash sales or regular sales or something. I just wanted a NW L2-HI to play with, and didn’t want to reflow a HI, screw around with seeing if it’d focus in a non-HI reflector, blah blah blah, all the usual nonsense. For once — ONCE — I just wanted an off-the-rack C8 that I wouldn’t have to build from scratch to get rid of the usual annoyances.
For some reason, I thought C8s used a regular 105C, and that the different UIs were just in firmware.
Didn’t even look to see if there’s any AS5 or anything under the star. Would be just my luck to have it mounted dry…
I thought so too (well, 105D) until people started getting the new silver C8s they ordered. Wasn’t expecting the driver hardware to change, just the firmware. Hopefully the next version will fix the little issues we’ve found — grounded pin 5, components too close to the MCU, and some slightly skewed fuse and PWM values.
Hey all. I’ve been away for several days. Tom, thank you for doing the extra investigating. I already reported the first finding (wrong fuse values) and now I see I have at least one more issue to report with the grounding of pin 5 on the MCU. The components being too close was reported a while back. These things should all be corrected “soon” but as busy as they are right now it probably won’t happen until after the holidays.
Btw, I found the close components did not interfere with the blue clip. The problem all along was the grounding of pin #5. At least this is what I found with the 5 boards, and two types of clips, blue and black, I have here. All 5 boards now have the pin #5 trace cut and all 5 can be make a connection with the clip, regardless of the closeness of the cap and diode.
I still see two problems:
on 1 of the 5 boards, it's consistently acting as next mode memory, even after re-flashing a known good firmware version of Biscotti. Replaces the C cap - no change. Bad part of this is it trips the 10 quick taps for config UI easy. I can only assume it's this one MCU -- the "noinit" storage lass of "fast_presses" doesn't seem to degrade to 0xff.
after programming the low byte of the fuse to 0x75, all 5 boards now turn on the LED at a very low setting when clicking thru to enter the config UI. I believe this is a direct result of using the slower clock, lower PWM, and keeping the PWM in FAST mode when setting the PWM output level to 0. 0 value still causes the LED to go on at a level lower than the moon level. This isn't a bad issue, just behaves different than expected.
