New High CRI LED
:rotating_light: The EC150 is available! :rocket: Grab it now at an exclusive 30% OFF launch price! :tada: Limited-time offer, don’t miss out! :alarm_clock:
:date: Available: May 19 - May 26, 2025 :point_right: Shop now: https://www.skilhunt.com/product/ec150-aa-14500-usb-c-rechargeable-led-flashlight/
#EC150 #LaunchDeal #LimitedTimeOffer
Looks like it’s using boost/boost this time as the picture suggest for Li-ion.
950 lumens for 519A so I guess the driver is 9V 1A so 1A per emitter.
I think Vapcell F12 or F15 will suit well for this light
Looks like a great light. I have 2 questions about the charging:
  1. Is reverse polarity protection present
  2. Does it charge usb c-c, with pd negotiation, or is it hard limited?
I ask, because on your product page the following is stated:
Text on product page:
Connect the USB charging cable to an external USB power source,
then attach the other end of the cable to the charging port of the light
(Recommeded USB power no less than 5W (5V 1A) )
The red indicator means charging, when the battery charging completed,
change to blue indicator.
Rechargeable function only for one 14500 (3.6V / 3.7V) rechargeable lithium battery!
When the battery is incorrectly insert the light,charging will damage the charging circuit.
With a 14500 I wouldn’t go over 500 mA anyway, that’s the bare Minimum of any C port is fine… Active negotiations won’t help.
  1. Reverse Polarity Protection:
    The flashlight has built-in reverse polarity protection for normal use. However, reverse polarity charging is not supported. Short-term accidental reverse charging may not cause immediate damage, but prolonged reverse charging can harm the battery.
  2. Yes, the flashlight supports C-C charging.
Purchased … thanks for the discount … :beers:
Now that the 4500k 519a is not in production, would Skilhunt consider offering the 4500k B35AM as a replacement? It would be perfect for the M200 and H04/H04R.
Better R12, no angular tint shift, and full turbo brightness at low battery voltage.
The B35AM would also be great in an M150/H150 using a boost-only driver.
@SKILHUNT Any news on the new M150?
Whats the coupon code. Showing $47.80
I hope it will release very soon.
Sorry, the offer has ended.
:star2: M150 V4 Flashlight – Your EDC Essential! :star2:
Compact, EDC 850 lumens. Powered by AA/14500.
:tada: 25% OFF from June 9–16, 2025! :tada:
:point_right: Shop now: https://www.skilhunt.com/product/m150-v4-edc-aa-14500-usb-magnetic-charging-flashlight/ #M150V4 #EDC #LaunchSale
The lanyard hole of the tailcap looks really nice, much better than the EC150 one. I also like the amount of LED options.
Which driver is in this light. Is it generic.
When will the white be available?
Are either of these batteries any good?
I’d probably go with the 113 for the higher mAh rating and usb-c charging.
The white version is still in production and hasn’t arrived yet. We’ll update the website once it’s in stock. Thanks for your patience!
Do all of these have the “V4” engraved on the unit, versus reusing old V3 tubes"?
