NEW!!!! T30R Laser Flashlight
They are much lower wattage than what most of us are used to on BLF. Max current draw is often under 3A and voltage around 4V. So 12W? That’s less than 1mm² Osrams. Long focal length convex optics likely only let out 50ish percent of the lumens on top of that. So all things considered, I think they do well. A recoil LEP is another idea that I think would be awesome.
Does wavien collar work for LEP setup? I hope it does as it could potentially double up the intensity which is crazy.
I am not sure, I think wavien collar works for LED is because the light source emits light in >100deg of direction, hence the collar is able to “recycle” those wasted light to the surrounding back into the die itself. But in the case of LEP what is the light emitting angle? I mean if the angle is already small, like <60deg (I really have no idea), how well could wavien collar “recycle” the light?
I see no reason that the emission would not be lambertian. And others have tested collars with LEP I recall with good results. Maybe not the 2x we’re used to but still significant. There’s some math behind it that seems like cheating physics but matches real world fairly closely. I’ll have to track that discussion down…
If you want to buy ,please visit the eBay store:
https://www.ebay.com/itm/194239196053
Also we will give you an discount if you fllow “Trustfire2020”
I sell a bunch of the Weltool LEP’s, really solid light all around. Not very practical indoors or short range. But Honestly it’s a great add on to AR type rifles. Good long range search lights as well. The guys I go shooting airsoft guns with absolutely love it. These lights are not for EDC use at all, mostly tactical/defense environments.
For T30R SOS mode,
we would like to say that the mode is hidden, and it’s not activated and start when you normal use.
The purpose is to make it easier to find and target targets when you being warning environments. such as search and rescue.
Our flashlight is professional tactical products,it’s must have this mode also is the latest program program.
please let us know if you have any advice,thank you so much.
