Ahh. I think the “-V”/do not verify probably means that it doesn’t verify that what it wrote/burned, i.e., it doesn’t read the results back in and verify against what it thought it wrote.
The “-F” means that even if there is no signature match, go ahead.
It may be flaky communications (clock issue, bad connection or too long wires.)
Try a ‘-B 32’ in the AVRDUDE command line to slow the ISP communication down.
The chip is labeled tiny13, correct?
Is the signature always exactly the same, 0x000000?
Double check that the clip is wired to the programmer in the correct order.
As according to flashlight wiki on avr driver, I got to move wire 8 of the soic clip to pin 9 on my programmer so the MISO lines up correctly. flashlightwiki
I am guessing that is the only wire I need to move?
If not I’ll just strip all wires and manually wire the required cables only by starting fresh
Edit: I decided to take out the cables and wire the whole thing again and I got this message
Try again. If the device signature changes each time you try then that is a sign that the clip may not be making a good connection to all the pins on the attiny.
I think i did something wrong to the old board or it is a faulty one to begin with.
The old nanjg 105d kinda died and no longer switches on after trying and trying
my new update on a new (and final 105d board) gave me a positive result
I guess I’m getting a greenlight to flash a new firmware to it then.
Since it is a 105d with no stars, any suggestions on what firmware to flash?
I’m afraid it’s still no good. Wrong signature and those fuses that it claims to have read can’t be right.
“avrdude: Expected signature for Attiny13 is 1E 90 07” is saying that the signature it got is wrong. When it’s working properly this message will not appear.
Do you have the ground pin coming from #8 or #10 of the USB AVR? Pin #3 is not a ground - flashlightwiki is wrong about that with the USB AVR's we are using today. Mine was wrong literally for years and happened to usually work for the 13A's, but did not work reliably with the 25/45/85 MCU's - I switched the ground to pin #10 (from #3) and all my problems went away.
