New version DRY driver info thread goes here
What you say Comfy makes sense to me. Your 4S to xml2 measurements above say alot too.
With 3 series XMLs and 3 series cells, shorting the resistors should make it act like the older driver. If one LED won't fry when direct drive off one cell, 3 won't fry when run direct by 3 cells. Knowwhatimean?
But for other LED setups (1x MTG2 with 3 cells, 3x XML with 4 cells), it'll need to remain in buck mode, which means no shorting across the sense resistors. I don't know if it has a falls-off-the-cliff point as the resistance is reduced like the S1100 driver, it'll need some careful experimentation to see how far it can be pushed.
I hear you. Like you said before the last post, (paraphrasing) the jury is still out on this driver.
The old version would not buck in 'turbo', this new one is much more flexible. I still have no idea what the stars are for. |(
I checked the circuit of the photo with the QX5241 data sheet and found that the right side of the board was the same as the standard circuit on the data sheet. The uC should be Microchip uC or similar which Pin 4 is Vcc. I wonder the wiring of the FET at the left side which look like not be wired parallel with the right one.
FET on the left has the drain going to ground, one on the right goes to LED-. But they're in series - source for the one on the right goes through the vias to the battery side, to the other set of vias at the left FET's source pin.
LED- > drain > source > source > drain > ground
specs from taobao.com
PCB diameter 32MM, double panel! Thickness 1.6MM!
On the circuit to do a lot of cooling holes! Dissipate heat better! Positive MSO tube heat dissipated by the inductor!
With reverse polarity protection! Output open! Short circuit protection! LED does not take damage!
Positive and negative output LED does not come together to burn! Barbara's multi-protection circuits!
LED: the single T6, U2, U3, MTG, ST-50, ST-90. 3 12V can concatenate strings T6, U2.
Dimming circuit with four groups! Especially for DIY! (Two five-pointed star shorted together to achieve the appropriate exchange group)
Default: 100% 30% 5% Baoshan SOS
A group of 5% 30% 100%
Group 2 100% 30% Strobe
Group 3 100% 50%
No matter which gear closed in around 5 seconds! Automatically reverts to the first gear!
Because a large board area, power walking fast heat bulk! Work to stabilize! 2.8-3A current is definitely not a small circuit board can be stability ratio.
Current default :2.8-3A, ensure stable! After a long test!
I just installed the new Dry driver in a Tangsfire 3XU2
The emitters are XM-L2 U2 on Noctigons, and everything is wired with 18AWG wire.
With three fully charged KingKong ICR26650 I’m getting 3.4A at the tail in turbo. I was hoping for a little better. I’d really like to see 4A. I’m considering trying the old 20mm Dry driver to see what it’ll give me. Is that driver known for Squealing.
I’ll charge up my E-Moli cells to see if there’s any improvement. Unfortunately the cells are so long I can’t even engage the first thread of the tailcap.
Somebody has done the resistor mod and got high current draw. I am thinking would jumper the resistor gives true direct drive?
I need pictures.
See post #13, not sure if that helps?
I am on my phone now and unable to look into it properly.
This new driver is regulated in all modes unlike the old one. Turbo is not direct drive, it's 3.5A. Since you have 3 LEDs and 3 cells, input amps will be fairly close to output amps, but it is NOT in any way direct drive. Bypass the resistors if you want more and are OK with it being only suitable for use with a matching number of LEDs & cells after the bypassing (you'll have to undo that if you later want to use it with a single LED and 2 or 3 cells).
Gate for the FET on the left connects to Source by way of 20k of resistors. It’s those two series resistors marked 103 (10k Ohm) for a total of 20k. It appears that the PWM output from the MCU to the 5241 buck controller also has a 10k resistor connecting it to Source (marked 1002). I do not understand the purpose of this arrangement. When the PWM goes high the lefthand FET either becomes forward or reverse biased, but I am becoming confused. With my limited understanding I thought maybe that this was a hack to use the 5241 as a synchronous buck controller, but this does not appear to be the case.
-Side note: it may be fair to assume that the 5241a is just an even more generic 5241 than the others (LY5241, QX5241 and SM5241). Here is a listing on DinoDirect selling 5241a’s as “other brands” of QX5241… I think. oh, nevermind. Of course it’s just a generic QX5241, the a/b designation relates to feedback voltage. It’s right there in the QX5241’s datasheet.
Hi guys
Can be used with 2 batteries in series and 3 series xml2?
Thanks!
No, it is not a boost driver. Output voltage will always be lower than input voltage. 2 series cells = max 8.4v, 3 series XML2 would require ~9.1v to run at 1 amp, ~10.3v for 3 amps.
:frowning: :_( …ok many thanks.
Well to be accurate, yes it can be used with 2 cells, and yes it can be used with 3 series XML2s, but not both at the same time. 3 XML2s would require 3 or 4 cells. I guess you could use 4 18350s?
Not come to understand well … you say that for some series parallel combination?
About of the 18350 is a good idea! but I can not use where I want to install.
Thanks
Input voltage must always be higher than output voltage with this driver, however you wire it up with whatever parts combo. To use 3 XML2s in series, the input voltage must be higher than the voltage needed to run 3 series XML2s. With only 2 cells you only have 8.4 volts input, but 3 series XML2s need more than 10 volts. That means you need more than 10 volts input, that means 3 or 4 cells (12.6 or 16.8v) input.
If you cannot change things around to get any more input voltage than 8.4v, you would have to wire the 3 XML2s in parallel, which would not be a good way to do it, since with LEDs in parallel the output current will be divided equally between them, that means it would only run at something like 1200mA per LED. If you wire them in series and raise the input voltage to 12.6 or 16.8v, the output will be 3.5A to all LEDs.
Why is it you can't put two 18350s in the place of each 18650, which would give you 16.8v input?
