someone tell me if the LED only the 90.2 might be able to fit in the emisar d1s would love that combo or let’s hope emisar d1s-v2 is coming with something like this led?
Beamshot please…
Please find some professional beamshots made by Bluzie (TLF admin) here:
Gheez! What a light, 4000 lumen ansi on turbo. Thank a lot…
Seems like the 40T is perfect for this LED…now Hank has no excuse not to put it in the Noctigon K1
Nagonka:
MOON: 50lm
Low: 570lm
Mid: 1050lm
High: 1900lm
Turbo: 4950lm
Turbo after 30s: ~ 4000lm
Turbo pulls out about 22A from a 40T
Also said a full Shockli 5500 does only 3750
Someone else said it reaches 70.6°C after 1.5 minutes. There was no step down even after 3 minutes
Hopefully, someone would mention their respective candela measurement, but just know the lumen value.
I would not say it’s perfect. It has it’s pros and cons. Some people might want longer Turbo time so they use a less powerful battery. Some people might want the longest runtime at med brightness level so they use a higher capacity battery. Pick the best battery for your needs.
Received mine yesterday. It’s a nice light. I measure 240kcd with a 40t. I was hoping and expecting a bit more. Like in the 300 range. I need to measure the lumens later.
But the memory is kinda finicky. When turning the light off in turbo, sometimes the light will turn on in low mode, high mode, or turbo. And I had the light on turbo for 5 or more seconds before turning off. And I waited 5 or more seconds before turning back on.
I tried like 20 times. I will test it some more when I get home from work today.
At how many seconds did you measure the throw?
About 980 meters for those wondering.
Been reading on TLF that driver (or switch) act weird, jumping through modes...
I don’t recommend putting a 21700 in there because it is longer than 26650 and will crush the springs. I had two Nightwatch NA40SE where I tried to use a protected 26650 and it permanently crushed the springs. Output permanently decreased by about 25% when using the same unprotected 26650 due to reduced spring contact pressure with the battery resulting in higher electrical resistance.
If reflector cup design to hit 1km, sbt 90.2 might be suit for it??
efficiency : it draw a way too much current, 20A? and not giving it best perfomance, instead overperform and exhausted in the initial turbo…but not that bad, probably its host undrestimated high current passing…
In terms of heat shedding, the host is as good as it gets. Probably the only thing that can be done to extend turbo is to use a copper shelf/pill like the Nightwatch IRA that used to be available from Enogear.
If this thing can hit 240kcd, that’s pretty impressive already since the head size is about the same as a GT Mini and D1S which only throws 130kcd.
Don’t you think that it still have very big room for improvement? I think so…bcos it supposed to beat gt mini and d1s
Actually, I didn’t have a 40t in the light when doing the testing. It was a red 5500 vapcell 26650. So it can possibly hit 300 with a 30t 21700.
So I got 5300 lumens at 30 secs. Nice output!
5500 lumens with the 30T at 30sec?!! Holy Cow!! Please remeasure the throw.
My Acebeam K75 only gets 4,100 lumens at turn on.
Everything has pros and cons. This light beats the gt mini and d1s in brightness (by a lot) and in hot spot size. It beats the gt mini in distance as well according to my gt mini results of 148kcd = 769m.
Toykeeper measures the D1S at 124kcd / 703m.
Where do you see room for ANY improvement?
Very big room for improvement? Would you like a flamethrower instead? That heats up things quicker.
