I see what you are saying. That concept is TRUE foe some of my Vinh lights that demand more amps to sustain max power. Those IMR cells[Sony VTC4/5, Samsung 20R] and NCR 18650PF will work better than a genuine Panasonic cell.
However, for my TK75,Panasonic cells have worked fine for the last 17 months!
OP’s issue is weak cell[s] or a charger that does not charge them well enough. I would be surprised if it were the torch.My guess would be the CELL[S] .
The runtime is around 45 min, on turbo, or 50 max, before the light start to drop to high mode, after few minutes (1/2) or even 30 seconds later on. Do you have 2900lm version? could that make the difference?
3/4 times from the time i own this batteries, i used them hard to the point the light would give low voltage warning, could this damage the cells? or shorten the life? they are around 1.5 years old but i think 14 months or so is the correct age. And maximum of 50 recharge cycles i would say even less.
I have the ORIGNAL version,yes, that could make a difference. I heard the 2900 version steps down after 15 minutes and your total run time on turbo may be less!!!
IS YOURS THE 2900 [NEW] Version??? If so, there may be nothing wrong with your batteries,you just get less run time w/ that version.
I RE READ YOUR POST!!! IF your batteries are about 1.5 years old[like mine] there is NOTHING wrong,you run your torch hard like mine and the batteries are getting older!!!
But i never use my light hard, i just wanted to test to see if anything is wrong or not, having read your answer, i think i get like 15% less runtime then i should but i guess its ok.
I just cant understand how Fenix is getting 75 mins runtime on turbo with 2600 mah cells, and i can’t get more then 50 with 3400 mah….
Keep in mind that the 2600 (im guessing they use the sanyos) are able to hold a higher voltage longer than the Panasonics, even though they have less mah.
Perhaps that has something to do with it? Doesn’t explain why its such a large difference in time however.
So in short, you get 2x runtime compared to me! you got protected cells? was told now that the turbo on 2900 lumen is 15 mins, so the runtime on turbo is even less ~35 mins! that’s terrible!
Its very disappointing to know that my cells are probably gone bad. If anyone can test with fully charged Panas 3400 mah protected 20 mins or 15 mins on turbo, wait 5 mins and then measure the voltage i would be very grateful!
