Well, if this new TIP doesn’t turn on in my pocket when unlocked, like the TUBE always did, then it’ll be OK and I’ll keep it. BUT, if it turns on in pocket, back it goes and hopefully an upgraded version emerges soon.
1. Great Beam!
2. High CRI option!
3. Do NOT use Lockout, it drains the battery in a few days
4. It has mode memory, so if concerned about accidental activation, consider turning off from Low.
As funny as the name sounds, it’s apparently a legitimate device. It’s a rolling, distracting, disorienting light source meant to draw the bad guy’s attention away for a moment so you can make your move.
Since the Tip ’n the Tube turn you On prematurely, try a light w a Twisty to get Off reliably.
If you got a new Tool, you could stop playing with your NiteCores.
Nitecore is sending now lights with improved drain in lockout mode.
Do you know if this gb is active or is dead?
(here with a microUSB cover bought in ebay):
(the pics are of my old model, high drain in lock out mode, now testing without lock, is more than 20 days and battery is maked yet as more than 50%, but I would like bought one improved model!)
