Well, I found others mentioning this same exact problem with a new MM15. Yes - same thing happens to my TV cable remote after some time - you have to press harder and harder... But this is as it was shipped, so different, but the same (?). I could get used to it, and now that I know, it makes it much easier to use. I'm thinking not all units have this issue though. Probably one day I'll see if the switch can be accessed - maybe I'll find it's not aligned properly. I should just start a new thread and take a poll because I know there are a few BLF'ers with this light now, modified and not modified.
that’s kind of weird. If I copy and paste the code it doesn’t work. But if I just type it in it works. Oh well, got it working. Now I just need an ‘installment plan.’
I have this light http://www.niwalkerlight.com/content/?275.html
The switch is damaged though I did not use it much at all. Now it doesn’t have the 2 clear level clicks. I can only do a soft click and it turns on low or mode 2 I guess. If I click strongly it will go to turbo.
I can’t change modes.
How do I fix it? How do I open the switch - it has 3 dents in each corner
Where do I get the replacement switch?
