There is a very big difference between going “dead” and just turning off. It’s okay acceptable by the vast majority of users for the light to turn off after a drop as long as it can be turned back on. Can you please tell us if the light was damaged or if it could be turned back on?
How is it OK if the light turns off after a small drop?
If the X9R was dropped or banged during a police raid, rescue operation or caving expedition and went dead (or turned off), lives could be put at risk.
A small drop caused it to go “black”. To me, that means it failed.
The difference is being able to pick it up and keep using it or having to ship it back to Olight for repairs. That’s a big difference.
So I think your opinion about it turning off in a drop being a fail of the test is in the minority. (Still a valid opinion if your standards are super high)
So many lights do that due to the battery springs compressing and briefly loosing contact turning them off. It’s kind of normal. I think if the light still works, the majority of people would say that test is a pass.
Drop test means that light should survive so u can press it on again once u pick it up, if it turns off the second it hits the floor isnt a big deal - if the light after doesnt turn on then you got one hell of a problem.
Ive seen videos of R50 drop from a bridge lol, it got some scratches but turned on after just fine, but i asume this light since so heavy wouldnt survive a big fall like that but who knows…
Everyone has their own standards. Like for me, I don’t care if any of my lights are waterproof at all. I don’t use them in the rain or around water. So I don’t care about IPX-6 or 7 or 8, etc…
I could not say without looking at the inside of the battery pack and how the pack connects to the head.
Finding pictures of the internal workings of a flashlight battery pack is a lot harder than you think. I’ve seen a few, but none were from Olight. I guess people usually return a defective Olight battery pack under warranty instead of cracking it open to try and fix it themselves.
Has anyone seen pictures of how the pack connects to the head? I guess you would need to photograph down the battery tube?
no cushion tailcap is empty more or less like on the astrolux lights etc , the small metal in the middle on the battery is what looks to made all the connection once inside the tube.
I tell u tho, it stinks like hell inside the tube, weird chemical smell or something really weird never smelled anything like that before haha…
I really don’t know where it could be temporarily loosing power. Maybe inside the battery pack? The packs that I’ve seen usually have each 18650 cell spot welded to each other with metal strips. So no springs necessary.
Generally speaking, I would have to say that lights that use battery packs are a lot less susceptible to a temporary loss of power due to an impact. It can still happen, though.
Some lights are much more susceptible. My Convoy L6 is pretty bad about it. It has two heavy cells in series that can pretty easily overpower one of the springs. Plus being short unprotected cells means it only compresses each spring a little bit. A good bump to the head or tail (which causes the batteries to move front or back) can do it. In my case the driver is set up to go turbo on initial power on. So if I drop it or bump it, it doesn’t turn off, it turns on! Lol
That’s odd that it went out a couple seconds later.
It could also be that particular light was an early prototype and failed the test and was rejected and all other lights sold to the public passed this test.
