Hello and welcome in BLF!
What do you want to make with it? What do you need?
If you want a 105D, you have to buy a 105D or 105C
Here in BLF are some similar drivers with similar Layout to the 105D which has more output channels, e.g. for some AMC7135 chips for regulated current and for a FET for unregulated maximum output.
Look at this topics for examle:
Let me introduce you to the Texas Avenger AKA the “TA” driver series.
Now in sizes ranging from 15mm up to 46mm and lots in between! Same design, firmware and parts for (almost) all of them!
Great project to put together and learn about electronics.
[image]
[image]
[image]
And for size comparison, it is easy to forget the size of these things.
[image]
This project is open source and you are welcome to use this work yourself for personal projects. However you must release any and all chan…
7. batch now active here
Attiny 25V running Bistro HD OTSM
OTSM works perfectly with lighted tail cap and hot light no more OTC timing issues
2S Bistro OTSM now on all sizes but 15mm available, 15mm 1S OTSM implemented with design change
or
Attiny 85 running NarsilM v1.2 with latest version with fixed bugs
Narsil manual , a lot options to configure this one
NarsilM driver can be thermal calibrated as well
you can choose the temperature for step-down, but change it later in User Settings
