Oshpark Projects
Thus I think STAR V1.1 and a timeout is the safest way to go
And/or have a approx 50% PWM always on…this way you don’t just run it wide open, I wouldn’t use that battery, it has vented…just not “explosively” yet!
Being an IMR battery it is unlikely to vent explosively, obviously something has happened to it, but it just now was still able to deliver 3.5A to the light. But I guess you are right, I will stop using the battery and dispose it .
I successfully rewrote my UI! :slight_smile: I made a new .hex file for the BLFTiny10 that replaces the 255 Turbo with 190, and the previous High setting with 90. After flashing the little guy I ran it through on the IMR10440 and it does .03, .31, 1.16, and 2.20. Perfect!
My TP has a Nichia emitter in it, don’t think it could’ve handled the full out direct drive. So now I get to try to make a contact pad over the FET and diode and then see if I can put it in my light. This is exciting! :slight_smile:
Woohoo! I now have a BLF Tiny10 FET in my Texas Poker! It’s running, from an IMR10440 at 4.15V, 3.45 Lumens a .02A, 34.50 Lumens at .18A, 127.65 Lumens at .67A and 262.20 Lumens at 1.40A! :slight_smile: Finally!
I had changed the driver in it before to get 188 lumens OTF, at 1.1A. So I’ve nearly doubled it’s output level on High or Turbo now, as it has 4 levels now to pick from. I’m stoked! :slight_smile:
Thanks Matt, for all your help, and Scott…this little FET is the charm we’ve been looking for for almost a year! :wink:
And the cool thing here? I’ve got the FET running at 75%! Can change it at will now, thanks to a lot of folks here that took the time to show me how, and got to laugh at me while I stumbled through it all. :stuck_out_tongue:
Is it known if there’s any adverse reaction to controlling the FET through the firmware? Say, setting max to 75? This is how I’m running my TP and it seems to be fine. And of course, the flashaholic in me really wants to find out what 80 looks like…90? :slight_smile:
It's no different than using a lower mode that uses the same PWM value (around 192?).
I set Turbo to 190 and Hi to 90, the lumens and used amperage work out pretty nicely. High makes 135 and Turbo makes 273.
Thanks for all your work with these MOSFET’s Comfy, really appreciate it, making this already loved light that much better! :slight_smile:
Oh, and for the record…no resistors for the gate or pulldown, works like a charm without em. :wink:
Which firmware? Fast PWM or phase correct? (if it's one of the STAR versions and you didn't change it on purpose, it's using fast PWM, hence why it doesn't squeal like a stuck pig). ;)
SWEET!
I am thinking the smaller 14500 and 10440’s will need a “choke” aka the 190 or 74.5% of maximum output…
So you always have a PWM control but it flows MUCH more power than any stock driver they can shoe horn in 10mm!
Awesome job!
oh and no laughing bro…we (especially me) are still stumbling around :smiley:
Oh and throw us up some shots of the Texas Poker light man :stuck_out_tongue:
I just noticed that this board is not listed here, so here the 7 XM-L board is.
http://www.brightlightmodules.com/Images/7xml_scaru.zip
Whoah…nice!
Is this on a copper sink pad or regular PCB material?
wow…all that XM-L goodness and head on 16mm…wow!
With a FET build I would be afraid to touch this thing off w/o having some sort of big ole honkerin’ chunk of copper/aluminum under it otherwise it WOULD become a torch :smiley: fwoooosh
Still crazy cool…
Is there an optic on the planet for this thing? (ooh…maybe under an aspheric on a SK98 zoomie) :open_mouth:
Regular PCB material, it has a bunch of vias underneath the XM-L to help with the heat problem. And it is a 20mm board. No optics available for this, I just run it as a mule in a P60 build. With a peltier plate for cooling and a desktop power supply it peaked at 26 amps. I think I may have been maxing out my power supplies though, so eventually I plan on giving it another shot.
Wonder what it would take to actually get this built on sinkpad?
Ah saw the 16mm 3x in the .pdf and didn’t look deeper…yup…20mm…still nice!
Going off of the cost of previous sinkpad group buys, it would be prohibitively expensive as I would have to order 1000+ of them.
This is the first one I managed to get installed in a light. 1.2uH inductor, no electrolytic cap. Levels of 2,6,18,54,130,255, and I shortened the long press time from 32 to 15.
I didn’t see it up on OSHPark…so I upped it (unless you want to put it there Scaru)
https://oshpark.com/shared_projects/hZGiHT7T
Nice…so the solder “feet” make good contact with battery tube?
NICE!
What is it running 4x XM-L and at what currents?
Anyone ever tried to dissolve the fiberglass PCB board under these above PCB “stars” and figure out a way to bond the overlays/traces to a hunk of metal?
It's in the one using the 6x parts. I have no idea what the current is, I don't have a meter that goes that high. On one 20R I get a reading of around 8.5A, but it gets significantly brighter when I bypass the meter by shorting the two leads together, so who knows what it's really doing.
I use an old SRK PCB to set the limiter on the drill press, then cut the solder down so it comes out the same thickness.
Thanks WH, I am actually going to order one of these, not to build scaru's monster but to make a moderately run efficient mule as a destination for the many last gen. xml's I have in the spare leds box.
