I think this can work, even with the attiny13a although I haven't tried it yet. I imagine you would use PB0 and PB1 as the output pins, driving the 7135s using PWM on the lower modes then switching PB1 off and PB0 (connected to FET) on to 100% PWM for the highest mode, or even at partial PWM for in between modes depending on how many 7135s you are using.
I use Attiny25's on almost all of the drivers I make but I use the 13's footprint when designing the boards (no particular reason why other than I had that library already). I've also used 25's on NANJG drivers without any problems.
Just need some of these coding geniuses to whip up custom firmware for the Tiny25 2k platform
Like 4 group driver like the 2 group Nanjg
1 group Lo/Med/HI w/ turbo timeout
2 group Lo/Med/HI
3 group ramping w/ double tap(or long press) turbo w/ timeout
4 group whatever they can think of
(hidden strobe in all modes)
What is 150 & 208mil measures of? Not doubting as I’ve never even seen any of them other than the 13A but I looked up the datasheet’s earlier and according to them the dimentions (of the SMD variants) are exactly the same.
When I lay out a board, I try to stack both the 150 mil and 208 mil footprints on top of each other… that way I can use either package without having to resort to pin-origami.
