Oshpark Projects
Excellent! Oshpark just gets better and better! 0.8mm PCB, 2oz copper, same price! :party:
Even the reduced thickness for drivers could give some space where it’s crucial, I guess.
So when can we see a µC-LTC board from you PD :bigsmile: ? Please?
Nah, just kidding. What’s the LTC Board you’d go with right now? I’d like to give this a try too.
What do you mean, µC-LTC ?
A lighted tailcap controlled by a small MCU. Something like mashm did, but with one or two proper boards for it. Yeah, and while you’re at it, please add a smd-fuse as a short circuit protection like LegolasGT did. Yeah if we could have them all combined, would be neat, don’t you think so? But again, I was just joking around. I’ve yet to try out any kind of LTC, so which of your boards should I try?
I can draw a board in eagle, but I don’t know how to design a circuit. Mashm’s solution is awesome, but I would need some help to do that. I’m not really sure what the point of the fuses is though. Seems like it would add a whole lot of resistance.
Of my boards, it depends how many extra parts you want to buy. I suggest reading the LTC OP and last few pages of the thread to see the newest stuff
Yes, thought that too. But I liked the idea of an additional safety feature for high-drain-unprotected-cells-power-build applications. I think he came up with that in combination with his 3,7V->6V 3A-out boost driver, maybe it made more sense in an electronics-way with that driver.
Since there will be less glass to conduct heat, you should probably cover more area with copper when laying it out.
I just did a mod. where the driver had to sit under the pill, as sometimes done on SK-68s. A thinner board would have saved me some filing.
What is our collective experience on OSH Park’s removing copper from the edges of the board? We are all aware that this is normally done. They require a 15mil setback for traces, but since our copper pours are not really traces it’s standard for us to specify copper right up to the edge of the board. Somewhere along the line a little copper is removed in order to prolong the life of the router bits used to cut the boards. How much are we talking about? I’ve just checked several boards using a feeler gauge and to me it looks like less than 0.2mm in all cases.
If you didn’t get your answer elsewhere already, the cap was moved due to a problem with voltage boosting upsetting the MCU. Comfychair, with help from other members, explored this pretty thoroughly in the FETs and gate resistors - scope images thread. Since the thread is now devoid of pics, here’s a link that shows the pics with the posts: Oops - looks like I’m having a connectivity issue right now so I can’t finish renaming this at the moment. For now you can go here and click on the link with a size next to it.
Exciting stuff on both counts. @pilotdog68 - looks like you’ve come a long way since realizing what vias were for! :smiley: :smiley: :wink: (#12)
lol it’s been a big year for me! I spent a couple months without a job, and what can I say… I got bored. Eagle was my outlet.
Silver linings, eh? Eagle being an outlet… yeah, no matter how much time you need to get rid of, Eagle is ready to use it all up.
I’m definitely interested in the illuminated tailcap business you folks have been playing with. I just haven’t had a chance to dive in yet.
Come on in, the water’s fine :bigsmile:
It’s a part of the big fancy groupbuy that’s about to go to the ordering phase. So in a month or two we will either have a few hundred raving fans, or a few hundred angry customers.
sub
Most likely a couple raving fans, a few hundred quietly content fans, and a couple dozen noisy, angry customers that will steal the show and try to make it look like a failure. :weary: I’m expecting to be one of the happy ones. :wink:
The thicker copper that oshpark offers now will wick away heat to the side better. Hmm, that could be interesting for ledboards too. There are many leds for which a dedicated board is not easily available, Nichia119, LuxeonZ, LuxeonC color line, to name a few. These can be made at Oshpark by using large poors to the side from the solder pads for heatsinking. Nothing for high wattage, any MCPCB will work better, but for low output builds it could work.
With heavier copper and shorter/thinner vias, maybe it’s time to revisit the solder-filled-via ā€œDTPā€ idea.
+1 I’d like to see some unique configurations made that Noctigon and Sinkpad won’t touch.
In my testing solder filled DTP works better than a normal fiberglass MCPCB does, but it is very sensitive to reflow and getting the right amount of solder (you need enough to fill the vias, but you don't want it to all be wicked away from the LED's thermal pad), as well as keeping the backside as flat as possible. Definitely usable for a hobbyist type situation, but definitely not for full-on production work. A copper DTP MCPCB is obviously superior, but getting them made in custom sizes is very expensive to get started (the initial setup and tooling is expensive!).
Hi,
I am working on this board, do you have any advice to improve it?
https://oshpark.com/shared_projects/jZxjYbXN
I recommend that you avoid placing vias directly on pads. Other people have already learned that the hard way.
Best practices also dictate not putting vias under components at all, but that’s just to make the circuit easier to read visually.
I have not looked closely at the layout. One thing which you may want to consider is how much of a pain it is for someone to do the Zener mod.
You all know where this is going . You can use this to program the tiny attiny25/45/85 MU MCUs. As usual, the spacing and via sizes are suitable for standard header pins. Like the other board, I have labeled the USBASP pins for easier hookup (I'm not the only one to ever mix those pins up, am I? )
Oshpark Link.
As usual, I have already tested it and it works.
