I see you paid, but it doesn’t look like Neal marked you down for the batteries. You might send him a PM about it. Keep in mind Neal sent this list on the 8th so it’s out of date.
Coyotewolf will add you to his list when he does the next update. It should be early January when you get a notice with all the details on how to pay for it.
Did I really understand that, with the XHP70.2 LED the Spot is good and no black hole is present ?
If that’s true then this LED should go into the Big Lamp.
After all lights were produced and shipped, a pill-section with driver and XHP70.2 and a short tube would be great, if it is aviable for buying.
With this it would be relative easy to swap between the two emitters.
After slicing the dome on XHP70, I’ve used 1000 grit sandpaper to smooth and mat the surface,and clean up after with isopropyl alcohol.
Tint shift is minor from 6500K to 5700K.
Results are great, similar to HI emitter but loss of lumens are bigger then I thought.
Lumintop SD75 running at 6 Amp gives only 3600 OTF lumens, so almost 20% less, but the hotspot and the beam are perfect !
