Yes, you just officially got on the list by asking here.
You will be added to the list when Coyotehawk updates it next.
You will receive a PM (Personal Message) in January with purchase instructions.
I hate to ask a dumb question but just out of curiosity would the GT float if it was ever dropped in the water? With its heavy weigh I didn't think there was a chance of it floating until I realized how much air is between the reflector and the glass. Still think it will be a rock but I am not sure.
What about with just 4 batteries?
The way I first found BLF was because I dropped the light I used every day into a creek shortly after the rubber switch cover tore. Switches don't like muddy water.
Volume is less than the mass of the light so no it wont float.
I’m figuring out the math but it’s not that easy as with a solid object.
(also i’m rusty with the math…)
The following statistics can be different than the final light as its not taking from the latest cad files. (all decimal
According to solidworks the volume without the battery carriers (thus increasing the volume of air inside the light) is 623114.50 cubic millimeters. That results in 0.0006231 cubic meter (0.6231 Liter) .
The mass is approximately 1650.78 grams.
With a solid object you would say that it has a buoyancy force of around 6.2 N (0.62kg = the displacement of the water = the volume of the light)
But since the GT is not solid, it has some trapped air inside, the buoyancy force would probably higher.
The empty battery tube has a inside volume of 7314 cubic milimeters.
I believe you if you say so, but was it that far fetched? Any idea how much the volume actually is? Supposedly less than 1.8 liters but by how much?
My quick approximation looking at the pictures is it will have more than 1 liter of volume, and my very quick calculations point to more than 1.5 liters. Just a battery tube as long as the light is almost 0.8 liters, not much smaller than three 1/3 liter cans of beer.
You might not need very large floats to prevent the GT from sinking.
See my edit above.
I took the values from solidworks. Dont know how accurate it all is.
I did some rough quick calculations and you are not way off with 1.5 liters. So for some reason I think the value that solidworks shows is not 100% correct or I am missing something huge…
When I make a simple cilinder with a diameter of 10mm and a hight of 20mm it shows a volume of 1570.80 cubic millimeters. pi r^2 h = pi x 5^2 x 20 = 1570.80. So that’s correct.
If a make that same cilinder hollow with a wall thickness of 0.5mm the volume changes to 362.07 cubic millimeters.
That doesn’t make sense…
Interesting question… but i can’t imagine it floating - even with half the batteries. Although i haven’t tried i don’t think any of my lights would. But none is this big. The extra volume inside the head is not enough IMO.
