weldtite TF2 looks perfect! ( and priced higher than superlube )
I took a look at the Weldtite TF2 you linked to, appears to be similar to White Lightning. I am not a fan of this for bike chains, prefer wet oil based lubes, but some cyclists in dry climates prefer it. My only caution on using it in flashlights is once the milk dries, it has a tendency to flake off - so it could work it's way into other parts. I'd test it on a cheapo flashlight (sparingly) and see if it works for you.
Well, for flashlights I wouldn't recommend it.
For one, it would be messy with flashlights. It's very thin (runny), with the dispenser orifice much too large for that (lack of) viscosity. You have to be very careful not to get it all over the place. Then there is the wait to dry. Then there is the potential teflon buildup...
I use it to advantage on machine guide rails. Have still to try it on feeding tables, like the planer's.
oops :shy:
sometimes i am plain wrong
sorry!
It would seem that yours dries up to a much "dryer" state than mine.
I still get a slightly greasy trace on my finger if I run it over the surface that has been lubed months ago (but not used much since).
Anyone here have any experience with this?
I saw a single reference to it on CPF with supposedly good results, would be nice to hear from others before I purchase. It's quite expensive for what it is!
Quote:
"This product is available to over 18s only"
Well it is lube..... ;)
I guess it depend on what kind of 'connection' you need lubed.....
got my "3$"-lube (i paid 6.89€, or 9.14$, for it) today. havent tested it yet. didnt come with a blister packaging. the stuff looks good so far. it does NOT look like oil but like liquified (silicone) grease. very viscous (viscid) and reminds of typical liquid glue. the transparent tube-like container is not hard plastic but soft plastic: squeeze it to control the oiler's output.
the oiler comes with 2 caps (yellow tip, and transparent cap) and a pocket clip. the pocket clip is rather cool -- it fits my AAA lights (in picture: Klarus MiX6), and it is branded with "SYNCO" (difficult to see in the picture which is a PC scan hehe) which looks nice too.
I am very glad that the oil doesnt have the physical consistency of oily oil (from your kitchen) but flows very slowly and "thick" .. like liquid glue.
Will test and evaluate the lube later.
If this product doesnt do it for me, then i'll give up. I have spent enough time, energy, efforts, and money on this topic. No further money invested in lubing products, no thanks! And all that §$%&! mostly because i was/am not willing to pay 8-10$ shipping for a mini tube of Superlube Grease (which is highly recommended on cpf as one of the best lubes for flashlights, threads and o-rings, made of any material).
yeah, sometimes i regret having gone the cheap route. budgee me. tss.
i have finally applied the superlube OIL on all of my 10(?) flashlights and i've come to the conclusion: this is the exact kind of lube that i was looking for, it works perfectly well and it gets the kreisler's shilly two thumbs recommendation:
kreisler's Overall Rating: ★★★★★
it works really well on:
+ o-rings (silicone, rubber, i dont know, i mean who cares, wtf)
+ anodized aluminum threads (e.g. Tank E09, Lumintop Worm)
+ non-anodized, bare §$%&! aluminum threads (e.g. Quark X AA)
+ twist zoomies (e.g. Romisen RC-29, Romisen RC-29a)
+ stainless steel threads (e.g. Lumintop Worm SS)
it does not exhibit stellar performance on:
+ Titanium threads (e.g. iTP A3 Titanium)
In all above cases, the stuff works much much much better than the Nextorch Silicone Grease C*ap. What else can i ? Since it's liquid, it easily flows into all grooves and slots with little external movement (e.g. twisting action). For example there is no need to lift or remove the o-rings; the oil would get there anyway. And now i am seriously wondering en quoi the superlube GREASE is superior for our application on flashlights. Maybe the grease is superior maybe it isnt, i dont know. I only have the OIL, and it does a fantastic lubing job: it effectively reduces the friction (drag/resistance) on the o-rings, makes the o-rings wet and "juicy", and also reduces friction in the threads, for two reasons: because it is non-sticky oil/liquid and because it contains teflon particles.
As mentioned earlier, the superlube oil is typically applied in fine rotating machinery, such as watches, clocks, and photo cameras. And since grease isnt commonly regarded as "liquid", i would assume that greased machinery parts produce more friction than fine oiled ones.
The only fear with OIL is/was: Isnt it too liquid, too messy and doesnt it run away?
My answer is: Yes, it is liquid (and viscous like liquid glue) but it doesnt run away. And no, it's not messy at all. ( *real oil* like the edible oils from your kitchen, *those* are messy stuff. surprisingly the superlube "oil" has not very much in common with what you would expect from a substance called "oil". not messy, not sticky. and easily cleaned/wiped away with kleenex )
I am not going to look any further. I know that there are even better flashlight lubes than superlube grease and superlube oil.. but i am satisfied already: reduced friction in the threads and on the o-rings!
Merely the performance on Ti-Ti threads (and SS-SS threads?) is questionable. My iTP A3 Titanium squeaks as if the threads were bone-dry: While it's better than bone-dry or the horrible Nextorch silicone grease, i am sure that there exists much better performing lube on Ti-Ti threads. Just a matter of price. As always. Because the more pricey option would be Nano-Oil, for US$ 16.00 shipped:
Also note that ChibiM has a relevant thread too:
Glad you finally found your magic lube, kreisler.
I have noticed that on certain lights the unanodized threads turn grey with in a short time no matter what I use - heavy viscosity chain oil or SuperLube grease. I think it is the ones with cheaper grade aluminum. On some I am curious about your experience with this phenomenon is with all your different lights. Can you watch and report back in a few days?
Sure!
the only non-anodized aluminum threads i have is the Quark.
As i use the Quark heavily (twist UI, tactical) i will report back in a few days, no prob!
( my Quark threads turned grey REALLY REALLY BADLY with 1x twisting with Nextorch silicone grease .. the Quark threads are soft and cheap, no doubt )
(Note to self: remember to turn espresso machine off)
Sure!
i can report already. after 3x twisting, the threads are all grey! To a similar extent as with the silicone grease. sigh. what can i say. the Quark threads simply **ck. too soft, and no anodization. i dont want to play the smart ***ck again but now i am thinking that no lube on planet earth is able to inhibit the fast abrasion of the **cking Quark threads. i am *already* using oil (which is better than grease or sticky lube) and i am *already* using a teflon-based lube (which is better than silicone-based lube because silicone-based lube does not contain teflon haha) and nevertheless i get the grey cr*p after a 2-3 twists.
i am glad about the low resistance: twisting is easy (o-rings are well-lubed). But the Quark threads decompose thru the minimal friction anyway.
and here comes the point:
Before i invest 15 or 20 bucks in an aluminum protective lube, i would prefer to invest the money in a new torch. With anodized threads. Never again a Quark!!
i still recommend the superlube oil .. but for nonanodized aluminum threads and titanium threads it doesnt fully do the trick. 3 stars out of 5.
I think it is a combination of soft alloy aluminum plus poor machining or threads that are too thin. I suspect the grey is bits of aluminum that flake off when you twist and mix with whatever lube you use. Not a problem with annodized, but also not a problem on several thick thread bare aluminum ones I have. Seems to be a symptom of cheapo flashlights.
Next up? I'm going to test shredder oil. I used to work for Fellowes and I forgot I have a bottle of fine machine oil used to lubricate cutter blades.
The quest continues.....
The quest continues…
I am thinking that the Quark threads were flaking from the very beginning (bone-dry state) and i didnt notice it because the aluminum powder was dry and mixed with the o-ring abrasions, dry too. i had been using a toothbrush to scrub the threads (and the brush got grey/black instantly). When the grey powder gets mixed with *any* substance (grease, oil, ..), then the abrasion becomes more apparent and visible: grey cr*p!, which should be removed the sooner the better before it does self-damage and accelerate the abrasion.
Quarks are not known for wear-resistant top quality machined threads (Sunawayman). If the Quark threads were anodized, there would be no abrasion -- no matter how poor and cheap the machining is.
If i ever buy another torch in future .. i will pay attention to this detail: all threads *must* be anodized!!
It’s even more frustrating as 4sevens Quark lights aren’t exactly cheap/budget lights.
Why don’t you email 4sevens and see what lube they suggest??
their suggestion is listed on their website: Deoxit
no way i am gonna use this. i had already trusted in buying the Quark "quality", that's enough.
from what i can tell, the Nano-Oil.com stuff should be the best .. but before i spend another 16$ on lube, i better buy a new anodized flashlight for this kind of money ;) Another Romisen or so. Apart from the choice of lubing product, the Quark's threads and machining is indeed "not on a quality level with Sunawayman or Klarus" .. to phrase it extra mildly.
If the threads themselves were thicker and top-quality stuff, then i would look into buying the Nano-oil; it would be worth the efforts and investment.
soft alloy aluminum plus poor machining or threads that are too thin. … symptom of cheapo flashlights.
Since the Quark threads are the way they are (you named it, i didnt!!), there is definitely no point in buying even better lube than the Superlube. I will continue to observe and report back. So far my observation:
Superlube oil kills the friction (mainly caused in the fat Quark o-rings) but the Quark bare aluminum still gets eaten up with the twisting action and you dont feel it because Superlube kills all friction. This makes one wish for a Titanium Quark (too expensive and heavy!) or anodized threads!!
Anyone has tested the esoteric Nano-Oil??
The precision lube at Radio Shack works great, thin enough and lasts. Pretty sure I read where it was similar to one of the fancy names. I put some on a friends Ti Q-mini and he was amazed how much smoother it became.
Bottom line, it works great, easy to apply, doesn't appear to deteriorate o-rings, and only costs $4. It is located near the soldering stuff.
I just bought a bottle of this same Radio Shack Precision Lube today, and it's great. I did a little research and lo and behold this is "Super Lube" oil. It's even got a "Synco" pocket clip on it. I assume Synco (makers of super lube) sells it to Radio Shack and then Radio Shack slaps their name on it. They call it "Needle Tip Precision Lubricator". It cost me around $3.99 for a 7ml bottle.
Radio Shack Precision Lube today, and it’s great. I did a little research and lo and behold this is “Super Lube” oil.
good info, thanks!
my superlube oil works extremely well on (any kind of) o-rings and anodized threads.
it kills friction in bare aluminum threads (e.g. Quark threads) but doesnt really reduce abrasion (build up of "grey crap" is still there)
on titanium threads it doesnt do anything noticeable. i even get build up of the grey cr*p which i dont seem to get with other/no lubes. thats why i dont recommend superlube oil on titanium threads. maybe superlube grease works better on Ti threads.
