Yeah, not a real problem i.m.o.
I use the ‘cigar grip’ most of the time with a tail switch.
Quite natural to me, since i often hold the light around next to my head.
Yes exactly that! I know you guys hold your hand up/near your head, but do you really do that if you were say, walking a dog or going for a hike in the dark?
In a situation where i have to switch to a higher mode, i raise the light to near my head.
This also helps the light reach what i look at when there are trees or bushes or whatever may otherwise cast a shadow.
When strolling with only low level light to light up the path before me i don’t need to raise the light.
It also depends on the switch and the switch boot and the distance between switch button and boot.
Some lights i can switch with my pinky finger.
My general rule on this is based on size of the light. Shorter than ~90mm and it needs to be a side switch except when it’s a slim AA or AAA light. Then it’s twisty or tail. For everything else under ~150mm long and ~45mm diameter, it’s a tailswitch. Larger than that and we are back to the side switch. All depends on fitment in the hand and distance away from center of gravity.
Most switches ive encountered need a reasonable amount of pressure to turn on. If anything, the slider switches were much more easier to switch on by accident.
Ive been looking at various brands, and im actually quite surprised how many models now have a side switch, lumintop and nitecore both do and nitecore has one with an interesting brightness wheel which I think also acts as the switch. That to me looks like something that would easily turn on by mistake, but im assuming it has a lock function.
I both agree, and disagree with all the points that have been made, or ones that have not been made. I like side switches that point up, but when I pick up a light and the side switch is pointing to the floor, I just cannot understand why they would make it that way. I feel the same about a tail switch when they switch the tail and lens of the light. My thumb is positioned over the lens and that just seems like bad engineering.
Ok, all kidding aside, there are many varieties of switch configurations. We all have preferences…my personal preference in NO WAY means that another person’s preferred light is inferior in design. Depending on the light, I sometimes like either.
My 2 switch Sofirn is excellent, and I find it easy to use, but my Thrunite Neutron with side switch only, also gets lots of carry. I just can’t wait until they have a light I can control with my mind.
Generally I prefer side switches because of the nice firmware. Tail and side switch is also nice but you can lock out the flashlight also by unscrewing the tailcap.
As I get older I favour a side switch because my fingers are not as nimble as they used to be. I have a slight problem in holding a light & using a tail switch with one hand.
I find a side switch with a big button far easier to use. I also put a drop or two of a UV glue on the switch to raise it & make it more accessible.
