I’m kind of curious about something: When I modified the light to direct drive, I kind of expected to see larger tailcap current than I’m seeing (~2.2 - ~2.7 amps that I mentioned earlier), esp. since I’m using an IMR battery?
I’m still kind of lazy, so to make the light direct drive, I:
- Cut the 4 pins between the “contact” PCB and the other board (the one with the inductor), i.e., so now, I only have the board with the spring in the light, using it as the contact board
- I soldered the negative of the emitter to the trace on outer edge on the component side of the contact board, but I couldn’t find a place to solder the positive side of the emitter (I didn’t try very hard), so, instead, I ran the red wire from the emitter to the other side of the board (the side with the spring), and just soldered the red wire to the solder joint of the spring.
In other words, all of the components on that “contact” PCB are still there, and intact.
I’m wondering: Is that why I’m only seeing about 2.2 - 2.7 amps at the tailcap, i.e., because all of those components that I left on the contact PCB intact, and they’re still sucking up current?
I’m kind of thinking about maybe physically cutting off some of the ICs from that board, but am kind of worried that if I do that, maybe too much current will go to the emitter (XP-G2 on regular, not Noctigon)…
I’m actually kind of happy with my current results, and the light is definitely better than it was stock, but would be interested in others’ thoughts…
Also, if I did remove those components from the PCB, would I need to add some resistor in-line?
Thanks,
Jim
