NCR 18650B cut off at 2.5V, if you discharge up to 3.0V still have some capacity left.
This is the datasheet
Can use HKJ’s comparator to get figure if cut off at 2.8V.
You may be able to test the battery directly, bypass the protection, without actually removing the protection. If you can lift up the pcb enough to get to the battery negative. Fasttech has new 18650 clear shrinkwrap.
