One thing to check — where the power comes into the circuit breaker box, if you remove the big main breakers — maybe this is where you call an electrician in. Anyhow from the pole, the hot wires on ours go down to where each one is screwed down with a great big hex nut.
And on our house, a few years after that was installed, those hex nuts had slowly backed out until they were just slightly loose. And we got that kind of odd intermittents, especially when and for a while after a big load like the washer or refrigerator motor started up.
I just got a great big hex wrench to fit, insulated the heck out of it, put my left hand behind my back, waited on a very dry day — and tightened the two hex nuts down really, really tight.
No problems in the ensuing 18 years or so.
I don’t recommend this. Kids, don’t try this at home. Your mileage may vary. Mr. Electron is Not Your Friend.
Just sayin’ — after checking all the grounding connections, the house ground, etc., there’s those from the pole to the breaker box.
These are the Furman brand conditioners, you can also hit ebay up and find some of the older models used cheap. Like $30 to $60! Nothing touches these. I have picked several up used for about $25. Just look around.
Cool part is that these will also kill all the buzz and or 60Hz hum found in some houses or rooms. I can actually hear a difference when using these. I have been running them for over 20 years. So far they have saved my gear 2 known times. Mine has a circuit breaker on the front you just flip if its tripped. Other cool part is that it will show you the load too. Very handy if you are running high amperage gear.
Anyways, just wanted to throw those out to you & others.
I lost some equipment in an electrical storm about 15 years ago. Same insurance issue here, it didn’t meet my deductible.
Not long after that I installed a 10 circuit transfer switch for generator back-up and while I had the breaker panel open I also installed a whole house surge suppressor like the one Bort linked. It was very easy as long as you have two open breaker slots.
The suppressor will not function correctly if you have a problem with your ground though.
Yeah, I’d never heard of those ’til visiting inlaws in Colorado, found them at a local hardware store hilighted as giving some protection for lightning-strike-related surges. (Not that it would handle a direct lightning strike on your home pole or wiring, but apparently they get a lot more hits on average from strikes on the power grid there).
Simple black box with a red LED, replace it when the red LED stops working — that was, oh, 18 years ago, still there, still glowing red.
Generally when the fuse blows immediately, you have gross overcurrent. That usually suggests that part of power supply is toast.
A filter cap may have shorted out, or a rectifier diode died (exceed the PIV on a rectifier, and it tends to fail in spectacular fashion. IIR the required
isolation for UL approval is about 1800 Volts. Exceed that and all sorts of ugly things can happen.
That sucks. I’ve never had an issue with surges like that, but I have my PC on UPS and my house has a natural gas generator as backup in case the power goes out.
> ground rod for the house
We did that 20 years ago. I think it was required by code, it sure was required by me.
I know the code warns about only having ONE grounding rod — even if you’ve got a long run to the far side of the house or shop, don’t stick another ground rod in out there unless you’ve got someone smarter than me designing a subpanel for you. Else you can get “ground loops” (no, not the kind you get by mis-landing an airplane) — noise and corrosion and the chance of shocks at best.
To hammer an 8’ or longer rod into the ground, you pick a time when the ground’s wet fairly deep, not rock hard; get a series of cutoff steel old plumbing pipe segments, that fit loosely over the ground rod; stack them so just a few inches of the ground rod sticks out at the top; set up a good safe tall ladder and someone to spot you (this is the dangerous part) and wale on it with a sledgehammer.
The steel sleeve keeps the ground rod from bending sideways in the middle, when you hit hardpan or a rock.
It’s damned easy to lose your balance when you’re waving a sledgehammer around; don’t be above that “DO NOT STAND ABOVE THIS” step ……
As you drive it in, remove some of the steel segments.
If the steel pipe is too snug it might bind. Then don’t forget to go out and tighten the setscrew every few years so the ground wire from the breaker box to your local ground is really connected; they loosen up, corrode, etc.
“… NASA’s online article about the science of this solar storm is well-worth the read. Perhaps the scariest finding reported in the article is this: There is a 12 percent chance of a Carrington-type event on Earth in the next 10 years according to Pete Riley of Predictive Science Inc.
“Initially, I was quite surprised that the odds were so high, but the statistics appear to be correct,” Riley tells NASA. “It is a sobering figure.””
That would wipe the grid out — in some places for years.
