I’m getting a bit picky, when I choose a keeper for myself.
I could use a 3 or more emitter flashlight with 3 or more 18650.
BUT, it should not have:
-Visible PWM, if any
-Battery rattle
-Preferrably no strobes / strobes hidden
-Other generally annoying issues or manufacturing flaws…
It SHOULD have:
-I like side-clicky on bigger lights
-Decent output, even when stock.
-Capability to use even protected batteries
-XM-L. If 1st gen, then neutral is mandatory, preferrably XM-L2 neut.
-Nice low. Nice beam (throw/flood not that important.)
Good form, easy to hold. If pocketable to jacket pocket, even better. It does not have to be huge.
Things I don’t care:
- How fast it heats up. Irrelevant, since I will use it only outdoors in longer terms.
Water resistance or IP-classification, just no need…
It would be difficult (not impossible) to find a pocketable light with 3 emitters/batteries. No?
How about a two emitter light like the MAXToch DX21? In tx shooter’s review he mentions this light would work well…at least in a jacket pocket. I’m still waiting on mine to be delivered…so I can’t attest to the quality…but when the dive version comes out it should have about 2k lumens.
Black shadow / Fandyfire Darth maybe? 3x 18650 with 3x XM-L U2 and pretty darn small for what it is, although the PWM isn’t supposed to be the best I’m not sure how noticeable it is in reality.
The ZebraLight S6330 would be my pick if it weren’t so damn expensive! I borrowed one of these once, and it was the BEST multi-emitter light I have ever used. Incredibly small, and compact, AWESOME output, and the best mode/groups of ANY light I have ever used. Once again, too bad its WAY $$$, and only a XML-U3 option. :_(
I have had a ZL headlamp and SC50. UI is spot on for me with that low-low.
199USD is getting a bit pricey I have to say but I checked HKEquipment and Zebralight.com: no stock.
It seems so, yes…
But: I have also been thinking of forgetting some specs and just get a High-Lumen triple with bad-everything to one hand and to other hand, a ZL SC600 Mk II with warm tint.
This ended up so, that I ordered a SRK “Kung” from eBay.
Seller sent me a basic SRK with not 4 but 3 emitters, wrong color and it seems obviously to be used before.
Sending it back.
