The SupFire M6 holds up well in the jolt test. I should re-test the lights, but I got a few with similar battery 1 spring mounts besides SRK clones, COURUI, Crelant 7G9, etc. I should re-check. The Q8 proto did the worse of the bunch I tested at the time, but I think the production Q8 is doing better.
Yep, been in the dark suddenly and it’s no fun. I use lanyards, belt clips, and the little glow-in-the-dark keyfobs that Andygold used to sell — on all my regularly used lights.
Living in an earthquake area, I want to know where they are when the power fails suddenly.
Yes, that is the way to go, but when Q8 driver was designed these ideas weren’t evolved. I guess it would be done differently starting today. I like to make the best of what I have before major mods like new drivers, and do so frugally. Easy to spend lots more $ satisfying desire, but I think the Q8 is a very good platform as-is. Just thinking about a simple 7135 stack at the moment, for my own peculiar preference, not suggesting it’s of interest to most.
On the soldering issue, some time back (a few years ago) I had trouble even soldering two wires together. When I first started modding flashlights it was aggravating. I broke down and bought a Hakko 888 (analog) and started using .031 Kester rosin core solder. Everything started going so smoothly after that! I got to where adding 7135’s was easy, would have 16 to 24 chips on all my Qlites! I don’t use flux, never bought a remover pen, never bought the braid (have always run a Tenergy silicone covered wire in the center of the spring). I did get a helping hands, it sits on a shelf all dusty.
If I’m building a driver and soldering by hand, the smaller bevel tip works wonders. I got away from it when I bought a hot air station from Justin, and since that one died I bought a heavier duty unit that’s a stand-alone hot air station. Now I pretty much always use the heavy 2 sided bevel that came on the iron. My pound spool of .031 is running low, about time to buy another I suppose. This spool has gotten me through literally hundreds of mods, well worth buying once and having the right stuff on hand.
I very truthfully believe that with the right tools, the right solder, virtually anyone can learn to be good at it. I grew up hauling lumber, shingles, sheetrock, mortar for the brick layers. I am not in any way an electrical engineer, totally sucked at soldering before getting the above kit. So really, if I can do it, virtually anyone can!
Edit: Proof is in the pudding? My SupFire M6 has a piggybacked FET driver of my own build, now fitted with 3 Luminus SST-40 emitters. Driven by TK’s ramping software. It makes 20 to 8866 lumens. Tail current is 28.74Amps.
The TA SRK 1+15+FET drivers with Narsil existed before the Q8 project started
it was simple not considered, even after I asked if it is still possible months ago it was declined to add more 7135s to the driver design
Time to look for alternative ? I think a previous poster mentioned one. It’s actually something you can easily mix up for yourself if necessary.
Fasttech quote ingredients as Ingredients: ZnO (24), NH4cl (30), Hcl (6), C3H3COH (30), H2O (12) and Surfactant (3)
Its the HCl and NH4Cl that are the key ingredients (sal ammoniac and muriatic acid in old fashioned terms), silversmiths, model engineers etc. have been mixing up their own fluxes for ages. Otherwise you might find a good silver-soldering flux like Harris “Stay Clean” is good enough (but it doesn’t have the acid and sal-ammoniac I think). Just the zinc chloride.
Actually I was surprised that GOOT could be posted, maybe that’s why it has vanished. Hanging on to my bottle, and will keep it for special occasions.
Now that’s the perfect motivation/argument right there to have a lanyard/glow ring/keyring light. All it takes is one trip or slip and you are effectively blind and incapable of finding your light again, assuming it is still working. I have been in pitch darkness outside once where I was incapable of finding my car, just 20m away. A single match would have been invaluable to me.
Lowest is PWMed 7135 which is also not linear (close, but no).
How are you going to catch it? I like linear mod but if I want to use it I will set with 3-5 fixed mods that includes one 100% 7135. After you can add as many chips as you want. But in ramping you will just pass this border (between 100% 7135 and low % FET) and wont recognize this easily.
This was down a steep wooded hillside, eventually found the torch maybe 50 yards below me. Limped home with damaged knee, three butterfly plasters needed to fix. Meanwhile found what I was searching for, thank goodness.
Not sure. I heard the switch LED can flash 1, 2, or 3 times to tell you which driver is in use. Until I get mine, not sure how it works. Programming in fixed levels may be the way, if ramping doesn’t give that info.
Maybe I’m mistaken, but I was under the impression that there’s not enough pins on the tiny85 to do both the triple-channel setup (extra 7135 bank) and the lighted e-switch at the same time. You have to repurpose that pin to do one or the other. So maybe that’s why we wound up with “only” a 2-channel driver in the Q8?
Oh well… that does not sound too good to me… Most lights just flicker and come back on when having a weak connection, going dark can be a problem in some circumstance. Remind me not to use it for off road biking at night, speleology or anything ‘tactical’.
Rosin solder is also bad, some are particularly sensitive.
Basically don’t breathe in solder/flux fumes. In production situations there should be at least a desk fan blowing the other way, ideally proper fume extraction (that’s what I’m used to seeing).
5 I/O pins: 3 chans, 1 switch, 1 SMD LED -- sounds enough to me, and yes, it will work with the latest NarsilM.
Because we don't need an external voltage divider circuit (R1&R2), it's doable. With 2S setups, it's not do-able currently.
We are talk'n 1 1/2 years ago roughly when the driver was decided on. Don't recall timing, but if the triple channels with full support (hardware and firmware) came out after the initial submission to ThorFire, then it was too late. For some strange, whacky reason, we thought the Q8 would ship well before the end of 2016 .
Ohh btw, I'm thinking the firmware was not ready in time for a triple, because the board layout still has pads for R1/R2.
