1440W is probably not available in the US because their PSU can’t deliver full power in the states. Crappy 110V grid…
Powerful device! 60V 30A 1440W max output under 220V AC, suitable for different situations, for US 110V version, it is 1140W
Why they have different listings of the same PSU at different prices - I really do not know The one you posted has 36% off, the one hoop posted has 28% off right now.
Yupper… and I apologize for the lack of communication…but it doesn’t allow me to find/select the US version of the same unit… That was what started this question. How to select that specific unit and price, but with a US configuration… I thought the question quite simple…but I guess I am not communicating all that well…
you mean the completely set ? there are choice to choose , if you are in EU, you can choose EU 220V plug version , if you are in US , you can choose US 110V plug version
you can also swtich 110v/220 by yourselves
hello, for now it is 11.11 sale time, the price is much lower than normal, and here is the codes provided by aliexpress, the quantity is limited, please use it when they are still valid
RD power supplies can charge battery, just notice that you need to use battery charging terminal and set correct voltage and current, it will use CC-CV mode to charge battery, for now it is sale time, the price is much lower, you can order one if you need
hello, some customers may not understand when charge a battery at 4.2V, when output is 4.2V, you see battery voltage is 4V, because the cable you use will consume power, you connect them together and you can see the voltage drop
hello, for our RD power supply, when using battery charging terminal, at different status, it will show you different icon, if you want to charge battery with protection board, then you can only use Red terminal as output+ and do not reverse the connection
