Those old-fashioned carpenters tools look great.
Good luck with your build. May it proceed well from now on.
Too bad with the “oops”. Hope your stock comes in soon and you can get back up and going.
And that’s a REALLY cool trunk of tools.
As I was reading some of the build threads , I saw a comment about thinking out of the box . I realized I have a lathe and don’t have to cut standard threads . I can make my own ! Sat down , did some math , and bingo ! Back in business.
Cut the internal lens cap threads…
Cut the body threads and thought I was good to go . I then discovered my pill wouldn’t fit . It 4 thousands over. So back to the collet chuck. This thing is only 3/4 long , so even with a collet chuck, it’s hard to set up.
The nice thing is , after turning the part around to finish , it concentric.
So it all fit together like I was hoping and is starting to look like a flashlight. Now on to the other end .
In case anyone may be interested, here’s a pic of the cutting tools I had to make for internal threads and to cut the small shelves .
Its handy being able to make your non standard threads. Love the home made tools.
very cool….
Starting to take shape and lookin’ good!
Started end cap for switch
Switch in cap
Test fit rubber boot before final dimensions
Made the retaining ring for switch by threading a piece and cutting to size
A look at driver in place
The shelf the pill sits on
Threaded
Body cut to length
Drilled and bored body
Here’s the finished light
I’m having a hard time configuring this driver , forgot how hard it is to “quickly tap 8 times “ Right now I only have 4 modes , but that’s 3 more than I started with .
I’ll try some beam shots , but I don’t think my I-pad is gonna do much with that .
Once again I wish I had a metal turning lathe and skills to use it….
yeah, I’ve begun mentioning how great it would be to have a lathe (and perhaps a small CNC) to my wife so that in maybe 20 or 30 years it might actually happen
Nice work
Thanks , that means a lot from such talented people
I have wanted a lathe for years . I bought that as my Christmas present last year with the intention of making flashlights. This is my first one . Internal threading to a blind shoulder was making me apprehensive.
This competition to honor Old Lumens , was the kick in the butt I needed to just go for it . I had fun , and I learnt a lot . I would like to say thanks to this forum , and all the great mates that hang out here .
Randy
Very impressive Randy! You made all of that look easy
What lathe did you decide on?
Orsm work on your first machined torch Rdubya18. Love your work.
I bought a Smithy 3 in one , mostly due to limited spaced . ( 2 car garage the cars still gotta fit in ) It’s actually been a really good machine for the money . For a hobby use machine it’s been able to handle what I’ve been doing . Because of backlash , threading into a blind hole is a bit of a challenge, but obtainable with diligence.
Yeah , but those kinda came back to haunt me . I only added .08 to thread , but then the pill didn’t fit so I had to resize it . Then I dug up a bolt to check threads on an end cap , forgetting the cap is no longer compatible , until I actually went to thread it in
The day I discovered my threading issue, I ordered some larger stock . My OCD would not let me patiently wait , so I decided to make a reflector head that would just screw onto my flashlight .
I happily started wasting some 2 in stock I had . Made a nice lens cap
I tapered it and was happy as could be
Then came time to cut the threads to length . That’s when I discovered another “ Oh no “ . I miscalculated the thread depth in relation to the LED height . It’s wayyyy too low in the reflector . Now that I cut the taper , I don’t know how to re-chuck it to extend the threads . The long threaded section below the taper is just there to give something to hold onto . It’s supposed to be cut off at the taper .
Hopefully I can use it on another build . If I make the pill longer , it’ll work , but that defeats its purpose of just being a screw on alternate lens type on this one .
Can you make a threaded mandrel to hold the head to machine it?
