Recommend a Sipik SK98 clone
Ahhh, thanks for the ideas :slight_smile:
Around the LED is polished aluminum so perhaps that is causing all the rings! I’ll try painting it with my flat black BBQ paint and see if it improves :slight_smile:
-Jamie M.
I bought the Ultrafire version, then modded it with a Nanjq 3.04 amp Driver with the High, medium, low, Moonlight modes, put a copper base under the star, and a de-domed XM-L U2 in it. Its a beast single-18650 zoomie light now. :slight_smile:
One of my XML FTTs has a polished & beveled bezel between 5 and 10mm deep on the inner side - I believe it is causing a lot to most of it’s ring problem. The light is copper HA so I’m not wanting to go with black. It might be OK below the bevel and around the lens.
Rings aren’t much of an issue for me on flood or outside and I mostly use the XML lights outside. And almost never on spot indoors, except for comparing lights to each other.
is the one woithout the hole in the heatsink?? the sipik has the hole-i want one without it…thanks…:slight_smile:
I modded my SH98 from FT, built a TexasPyro 20mm Nanjg OSHPark driver w/ 8*7135 chips, I now have a SH98 that has 4 modes, turbo w/ 2 min timeout, high, med, low and no stupid flashies or PWM that bothers my eyes (I could solder down pin 2 and get a moonlight mode, but low is good enough
I also epoxied the star down to the pill, and put some NOALOX on the pill threads to help pull the heat away from the star
I recently ordered Fasttech just because it has glass lens and hallow pill (call me crazy :bigsmile: ) but since I count on Chinese lottery I ordered 23mm glass aspheric just in case if my Chinese lottery luck let me down (and… it let me down, plastic and scrached :expressionless: ). Also, discussion thread “lens material” says that description is 100% true :Sp . Flashlight itself was dreadful. Lots of dings and even a deformation in the battery tube. Driver changed modes when I zoomed in and out (still mystery to me). Zooming mechanism was also horrid ( crunch, creaking and very hard to operate). However, I’ve buy it just for using the host for my next moding project so I didn’t bother much for all these quality issues.
the one I got from relic’s giveaway (fasttech) was with plastic lens.i also ordered glass lens but was not direct fit,the lens was a bit bigger.
I wonder if you could gently grind the lip around the aspheric lens w/o damaging/shattering it
Mine also wasn’t direct fit. I had to file down the nasty bezel that have had cut-ins for pres-fit the plastic lens.
nice idea ,I clued mine.
is possible to get the cabel for gun which can be used for sipik sk68?? i never saw it before…can it fit with any of available pressure switches???
http://kiev.ko.slando.ua/obyavlenie/fonarik-sipik-sk68-c-vynosnoy-knopkoy-ID74wGX.html
