I think some aftermarket fog lights are yellow, though I haven’t seen any like that in a while. Factory fog lights are not. I haven’t seen any that are at least.
I should probably specify their actual use though. I called them fog lights, but they will actually be used full time as a light supplement. I try not to ride in the fog on my bike anyway. Deer love to jump out when it’s cool and damp.
I haven't seen empty bike housings like that but since it also fits a WF-500 it will fit any 50mm housing including a Mag head. You could always go with that Skyray light, swap in the DRY driver for $5 and rewire the LEDs to series.
One driver per XML to get some redundancy in case one burns out and all that’s left is a generic fog light holder to house the whole unit. I never finished building my unit but it should work.
Can anyone advice if I can wire 4 Xmls t6 in series and run them off direct drive on a bike’s 12v8ah SLA battery? I mean how much current would flow into those XML?
Absolutely not. Automotive Electrical Systems have two problems for Direct Drive
1) They vary in voltage too much because of the Alternator - Voltage can easily be as high as 14V
2) They are capable of delivering hundreds of amps of current for short times. High voltage combined with High current reserves = Blown Up XM-L
You MUST use a (preferably switching) regulator for automotive systems.
Got another question, I like to make a 4xXml
Off road bike light using a driver http://www.kaidomain.com/product/details.S020121# rated for 3-18v & 2.5amp(with 4leds). I like to know how much current is going through each led when connected in series?
Your light bar sucked in the fog. That doesn't mean all LED's will suck in the fog. Optics and tint matter more than what actually produces the light. I bet your light bar had both a poor choice of optics and tint for use in the fog, and was probably poorly located as well.
Leds are to intense. You get the “high beam in the fog effect”. Smoke, dust, whatever. leds are not the chioce for this. Don’t believe me, Take your led flashlight outside when its foggy or smoky and shine it through. Colar can not “cut fog”. Amber help you render better but can not “cut fog”.
You're right, I don't believe you. Go put your device on one of your LED flashlights, go out in the fog, and lay your light onto and parallel with the ground. Try it again without your device while holding your flashlight in a tactical position.
Edit: Oops, I thought you were Daylighter. The point of that exercise was to show you that foglights depend on a sharp cutoff, a wide angle, and a position that's close to the ground and a good vertical distance away from your eyes.
