The Chinese are coming out with some excellent replicas these days.
They are even using decent steel like 9Cr18MoV, single liners that are drilled for weight savings and are rounded/beveled.
9Cr18MoV lands in between 440C and VG10, but is closer to 440C which is still a good knife steel and better than the 440J2 used on most of these replica knives.
A good Civi replica will cost $35, but with its limited use, how often will you use it for its intended purpose?
99% of the fakes on alibaba have dual liners and 420J2 steel, despite advertising VG10 steel.
The dual liners are a dead giveaway that it’s a fake. It’s like wearing a Rolex replica with a Quartz movement.
I have found just one vendor selling replica Civi’s with a single liner and 9Cr18MoV steel.
I might buy one to see how it measures up to the real deal.
One thing to keep in mind is that you will probably use this knife once or twice in your lifetime for SD, so it might make sense to go with a replica.
But then again, the pivot pin might break when you deploy the blade or have some other malfunction occur, so is your life worth the $100 or so that you save by buying a replica?
As for some people (Not on this thread) saying this knife is useless because you can’t stab with it, please, get a clue.
And I’ll take a Serrated “slasher” over a pointy “stabber” any day for SD
In a SD situation, the idea is to extract yourself from the situation as quickly as possible and not to stab someone.
A good slash to an arm, face, chest, etc…, especially with a serrated edge will put an immediate end to any attack or at least stop it long enough for you to remove yourself from the situation.
You don’t want to stick around and use deadly force and get into a knife fight or kill someone, no matter how much they deserve it as the legal bills will cost you a fortune even when you are legally in the right.
BTW, I’m selling my Civi once the Cold Steel Black Talon II hits the market — same blade design, better handle/ergonomics, Thumb plate opener instead of a bird’s eye, Ambidextrous clip and CTS/XHP steel that is better than VG10 at around $110 from reputable aftermarket resellers. (Ignore the CS MSRP)
http://www.coldsteel.com/Product/22BTS/Black_Talon_II_Serrated_Edged.aspx
