I have a question for you using this: How much amps do you get on high?
I seem to get “only” about 2.4 to 2.6 at best.
Could it be, that the positive spring is keeping it a bit low?
When battery gets a bit used, about 4.00-4.10, it drops to 2.2A or thereabouts.
…an that´s not all:
It seems to kick down to LOW (I have 2-mode) at about 3.80V-3.85V.
I think that is not acceptable if it is advertised to do so at about 3V…
It does seem to be kicking in a little soon. The driver will kick down to low when it is at 3v under load though. If you run it until it kicks to low, pull the battery and check the voltage, it will always be higher than 3v. How much higher, I am not sure. I would not be surprised if a light that is driven to 3a that cuts off at 3v would bounce back up to around 3.5ish volts
I failed to mention that the cell is a laptop pull with 1950mAh capacity, charged about three months ago and it has been in the drawer since (not used).
Just a suggestion or 2: Maybe try a better “Brand name” battery (Panasonic, Samsung or Sanyo cell)? One with more mAh’s, or one with more juice? Or maybe the same battery on a fresh charge?
I emailed Hank and he suggested I use a cell that can sustain 3A. That LG cell was one of the better cells I had. I have to try other brands I have, but all of them are laptop pulls.
I just got one of these in the NW tint and it has a disappointingly purple spill, even with diffusion film on the lens. : / Maybe I should have tried the Hi CRI version.
EDIT: Just realized the T4 5B1 version doesn’t do firefly mode so there goes that idea.
The T6 3C with OP reflector. The center looks great but it gets very purple-ish around the edges. After reviewing your pictures again it looks like the spill on your house and fence looks much cooler/borderline purple also. Maybe my standards are set too high but my NW D25C is much better around the edges. Everything else about this drop in is great though, especially the price.
