Sure, I always do check datasheets but what I didn’t know is what would happen, that is would the light draw too much current and the cell would burn or will the cell simply supply it’s maximum. Thanks for the info. So I guess it will be safe for me to occasionally use the turbo mode without worrying about burning my hands.
In a direct-drive light (such as the Astrolux C8), I think you’re fine. You won’t exceed the max rating of the battery, because the voltage will sag and thus drop the forward voltage of the LED.
In a light that uses a boost-driver (such as one that uses a 12v XHP emitter), it may be a different story. Depending on the driver, it might be able to draw more current than the battery is rated for. With a name-brand battery, it’s probably not good for it, but won’t result in anything exploding or catching fire. They test batteries with an external short (at less than 50 milliohms) to make sure they don’t blow up or burst into flames. IOW, way more amps than a flashlight would ever use.
I see. one more thing, what size is the rubber tail clicky? I don’t need measurements just need to know are they of the same size as convoy s2+ or not?
Looks about 17mm diameter.
I have one XP-L HI that does the same, the others i have don’t.
I dislike the Astrolux C8 stepping down after around 40-45 seconds (due to timer-based stepdown from BLF A6 driver).
Would it be possible to change it instead to the BLF X6v2 (Bistro) driver (driver swap)? That would give it more controls.
Why you could just change the delay time and simply reprogram your existing driver.
Is the Astrolux C8’s factory-included driver chip re-programmable with a USB ASP programmer?
(I’ve read that the Convoy drivers chip is “locked” and cannot be re-programmed…)
I ordered a USB ASP programmer and just received it a few weeks ago, but can’t seem to get it to work… I think it’s because the SOIC clip that I ordered is not holding tight or maybe the USB programmer is just picky? (will post question in appropriate message thread…)
Well it should be. If it ain’t then there are some tricks to program it.
I believe it’s the exact same driver that the BLF A6 uses, so if you can reprogram it, you should be able to reprogram the Astrolux. I agree the 45 second step-down is too short for the Astrolux C8. It should be 3 minutes, since the light has much more thermal mass and heat dissipation area, and can take at least 3 minutes on turbo.
Interested in this as well. Having purchased few Convoy S2+, BLF A6, I am interested in a thrower and would like to pick one of these two. Then, adding BLF Q8 and I am done buying flashlights for a while
Sure… until next week.
My Astrolux C8 arrived today. Tried to remove the tail retaining ring to change rubber button but the retaining ring is stuck. It isn’t moving at all, tried with more pressure but then the circlip plier slips and started stripping the holes on the ring. Any idea how to deal with this?
Clockwise to loosen, counterclockwise to tighten.
That’s how I’ve been doing it for all my other lights.
Are you sure about that? I don’t know what other lights you have, but my lights have a mix of standard and reverse threads for the switch retaining ring.
Oops…My bad. It worked. My other lights were counter clock-wise to loosen. So was the retaining ring on the driver section of this C8.
Another thing to mention is that Astrolux/Banggod only lubed the tail section threads of main body. The driver section and glass section were not lubed. It took me a lot of work to remove the driver section and it made a real bad screechy noise when tightening and loosening. Why Banggood why??
I was told by Banggood there is a new discount code for this light. Use the discount code 3a103e for 37% off the regular price.
BTW, this is my new “thrower” I carry when cycling this year, on a lanyard around my neck for easy access. It makes a great combo with the floody BLF A6 I use for my mounted cycling light.
Both the silver Convoy C8 (with biscotti firmware) and the Astrolux C8 (same UI as the BLF A6) have good interfaces. Whichever you prefer is a matter of preference, but they’re similar in modes and flexibility.
The advantage of the Convoy is you can set it up as a single-mode light. The advantage of the Astrolux is that it has hidden modes, such as battery-check. I normally set both up with mode-memory, so it just turns on to the last mode I used (usually max).
I use a Samsung 30Q in both lights. It’s a high-drain cell, which is especially beneficial for the Astrolux C8 because it has a FET+1 driver which uses all the current it can from the battery.
How do you set up memory mode on this C8? I don’t like how mine keeps starting from moonlight after i turn it on again
Turn the light on, then rapidly half-press the switch a bunch of times (10 or 15 should do). It will then do a series of blinks. After the second set of blinks, turn the light off. That will toggle memory mode on or off.
You might have to try it once or twice to get the hang of it. If you turn it off after the first set of blinks, you’ll toggle 4 mode or 7 mode. If you make a mistake, just do the same thing to toggle it back the way you had it.
