Yes, this is a very common but in no way it is a big issue
This is a step by step :heart_eyes:
1- Open your palm.
2-Hold the flashlight by the head
3-Push the head inside your palm
4 Screw clockwise
5 check rattling and repeat 3,4,5 until you hear no rattling,
you can also do it with a self healing pad or mouse pad….
I have 3 M21C-U. All came with reflector rattling. And all 3 the SS Bezel not tighten. Not sure if this is on purpose by Simon as some will prefer to change an OP into this light like I did.
Not a problem for me with them rattling. Once tighten SS Bezel, rattling gone.
By the way, I have more than 10 Convoy lights, all the Bezel came not tighten. Again, I’m not sure if this is on purpose.
This lantern has a different bezel mount design. The sealing ring does not rest against the reflector, but against the lamp housing around the perimeter. When tightened, the bezel first pushes the rubber band, and only at the end presses the reflector. As other participants in the discussion have already written above, when tightening, you need to press firmly with your palm.
Hope my “lame” english can be understood ).
I figured out how, when turned on, it is guaranteed to get into the first low mode. If you turn it on by pressing 6 times, then the control mode is changed with the inclusion of the minimum mode. The crutch is certainly uncomfortable, but it’s better than getting an unexpected turbo mode.
For some reason, the following began to happen with my flashlight: when switching from a stepped mode to a smooth ramping mode, in the first few seconds the flashlight spontaneously raises its brightness by three small steps, up to about 90lm.
I added 3 more beamshots of stepped ramping mode in the Beamshots section.
And it’s worth mentioning I edited the review after some time and added info about simple 4 mode UI available after 6 clicks. Sorry I didn’t mention it earlier, and I gave this flashlight worse rating than I should. I changed that too.
I put orange peel reflector on my lantern. As expected, the transition from hotspot to side illumination became smooth, the light became more convenient at close range. At the same time, I did not notice the loss of range.
I have an M21C U and also a M21C and M26C. What annoys me is the gap between the bezel and the body. My bezels also came not fully tightened. On the M21C U there were a couple of small burrs in the threads which I scraped then lubed the bezel and forced it past the burrs so it is as tight as possible but still has a small (maybe .25 mm) gap as do the other two lights. If you look from the side you can see daylight between the bezel and the body. Seems something is out of spec, likely the bezels. It bothers me as as the lights seem perfect otherwise. (except for the ramping issue on M21C U), and my other lights with the same type bezel (non Convoy) are all fine.
Alright thanks. I’m thinking of getting this light and swapping in a Linings SST-70. I have had very good results with that LED in my Convoy L6. Pure white, no ugly corona, good throw. Such an underrated LED!
Hello.
You’re right, you need to unscrew the stainless steel pressure ring located on top.
Can be unscrewed by hand counterclockwise while pressing the ring with palm. When reassembling (twisting clockwise), you need to firmly press the ring with your palm in order to firmly press the sealing rubber ring located between the silver ring and the flashlight body. Otherwise, if it is not tightly screwed, the glass may rattle.
Another question. After receiving my M21C-U it did not work. I contacted Convoy and they send me a new spring. After replacing the spring the flashlight works. But with 100% it steps back after roughly 5 seconds to low mode. What can cause this?
My new spring looks like this:
On other reviews I saw that the spring looks like here:
Why there are three different versions of springs and how can I solve my problem?
An additional wire (shunt) is placed when the spring cannot conduct the required current through itself. The shunt-free version has a spring with better electrical conductivity, Simon says. You may have a lowcurrent battery. For turbo mode, a battery with a constant current output of at least 10A is needed.
