I have been looking over and measuring my FF Rook, and i have determined there is just enough metal under the side “lands” that i can bore out the battery body to the size to hold a single 26650, or a single “C” size Alkaline, after machining out two spacers for the end cap and head area to lengthen it, to accept the longer 65mm Lithiums, and a modded base spring and forward contact plate. (This should give the Rook a better run time, and allow even a 18650 to work with a plastic side spacer.) also this will give me just enough room in the side of the battery tube to add a mini-clickie switch wired to the ground spring, to shut off the light and eliminate the parasitic drain when not in use.
Looks like i have a project mod here to do.
I haven’t forgotten my promise, Joat. Nor did getting to 2000 go unnoticed by me. I will be giving one away. In the intervening two years, I gave the one I ordered away, so I’ve ordered another one and once I have it in my hands, there will be a GAW.
