No problem, personally I’d get one of these since they are a more current LED and with the 2nd one you can choose the tint:
(only the 1-mode versions are 18v)
Choices are XP-L v5 or XP-L2:
https://www.aliexpress.com/item/Cree-XP-L-V5-1A-LED-Module-3V-18V-1-Mode-Driver-Led-Module-OP-LED/2034219825.html?ws_ab_test=searchweb0_0,searchweb201602_3_10152_10065_10151_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10307_5711215_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_5711315_10621_10620_10810_10811_5722415,searchweb201603_1,ppcSwitch_2&algo_expid=d9e9fe44-a441-470a-a0fd-83d8be938e4a-0&algo_pvid=d9e9fe44-a441-470a-a0fd-83d8be938e4a&priceBeautifyAB=0
Or these XM-L2 U3 (1-mode) you have choice of tints:
XML2 U3-1A Cool white 6500K
XML2 U3-3C Neutral white 4300K
XML2 U3-7A Warm white 3000K
https://www.aliexpress.com/item/26-5mm-CREE-XM-L2-U3-OP-reflector-LED-Drop-in-module-1mode-3v-18v/32837878315.html?ws_ab_test=searchweb0_0%2Csearchweb201602_3_10152_10065_10151_10344_10068_10130_10324_10342_10547_10325_10343_10546_10340_10548_10341_10545_10084_10083_10618_10307_5711215_10313_10059_10534_100031_10103_10627_10626_10624_10623_10622_5711315_10621_10620_10810_10811_5722415%2Csearchweb201603_1%2CppcSwitch_2&algo_expid=d9e9fe44-a441-470a-a0fd-83d8be938e4a-1&algo_pvid=d9e9fe44-a441-470a-a0fd-83d8be938e4a&priceBeautifyAB=0
But if you can get the one from amazon it might arrive faster and be easier for returns if there’s a problem. Not sure how Amazon works for Australia.
