Ok folks I also have the Trustfire TR-3T6 which is pretty much the same light with the same output as the Lixada 3800 Triple with both in stock form. I was wanting to know what these lights would do modded, but I have not modded a side switch light or tried anything with multiple cells yet so I was really hesitant to mess with this light.
Since the 2 lights are nearly identical, I sent my TR-3T6 over to Dale for a slight overhaul to see what kind of difference he could get out of it. This light was doing a disappointing 1389 lumens according to Dales meter when he got it, now with the tweaks he did (using stock driver and just tweaked it) and some dedomed XM-L2 emitters on Noctigons instead of the T6’s that came in it, the light is doing close to the rated 3800 lumens now with about double the amps it had stock.
As for the light that is coming out of it now?
Well I will let you be the judge of that with the beamshot comparisons below……….
Stock 50yds (High)
Modded 50yds (High)
Stock Gate 100yds
Modded gate 100yds
Stock 175yds
Modded 175yds
