For some of the samples ( reviews on " Fonarevka " , "Forolinternas" , Selfbuilt Review and some others...), the measurements for turbo mode are in the range of 5-6 Amps , BUT the run times in this mode are consistently OVER an hour ( 1h and 21 min , 1h and 15 min...) with 18650 batteries , of 2900-3500mAh , that is leading me to the conclusion that 5-6 Amps is NOT a correct value ( just do the math...)
More interesting is that , on my sample I did not noticed a step down from turbo after 3-4 minutes , as most of the reviewers...!
Also , the temperature of the body , measured after 30 minutes was under 50 degrees Celsius so , the temperature was under the kicking point !!!
To be sure , I tested the light with different types of 26650 batteres ( Liitokala , KeepPower and Soshine ) , fully charged ant tested before for 10A discharge , with low voltage sag at this current ..,and the results were consistently the same ...! Current on turbo around 3.7 A and the running times between 72 and 85 minutes , depending on the capacity of each battery ( 4200-5200mAh )...More than that , on the last test , at every 3 minutes I performed an " off-on" of the light , to be sure that is in turbo mode , all the time ! Making the math again , is clear that the current SHOULD be 3-4 Amps , in order to have more than an hour in turbo . If the current was about 6 Amps , how come the running time is over 1 hour , with an 4200 mAh battery ??????!!! . You see what I mean ?
What is going on here ? My light is so different , even if the driver is marked as all I've seen ( Manker DL046)...
I'm sure of all my tests and my measure instruments ( because I tested them on other flash lights that I have , is nothing wrong ...).
For sure , I do not have a " super " sample , somewhere the numbers are wrong , and not mine... the math is giving me the right to say so...
By the way , I measured the led current , is a constant 1.09 A , on turbo !!!
