Again I realize I’m over a year behind on this thread, and that it almost sort of turned into a Diving Light thread. Actually thanks Litebringer for bringing up the DV-S9, I’ve been interested in a slider switch light for a while and subscribed to your other thread on it.
- Thanks NikolaS for the nice video, obviously you are one who can see value in a budget light when there is some. I agree these are great for around the house.
- Thanks Wildcat for the link to the photos in post #28, very helpful. I’m not sure who’s photos they are but I don’t do facebook ATM.
I have two of these lights, one from Gearbest and one from Amazon. I really like it, I think it may be the best low price budget light I’ve ever got!
The Amazon one is a HOVINSO brand, and the Gearbest one is the “No Name” (Gearbest no longer includes a battery or the plastic case).
My 18350 shorty version:
I’m using a Jaxman 18350 tube with a Convoy S2 tail w/ metal switch.
The tube technically does not fit this light as it doesn’t really thread on properly, however it works just fine, the tube’s threads are a smaller diameter and only catches tight at the very end, but it’s enough to actually tighten and hold without any damage to either the tube’s threads or the head. (I’ve taken it on and off many times)
The Convoy tube doesn’t catch the threads for a good fit like the Jaxman. The Jaxman tube has a bit wider I.D. and it’s also longer than the Convoy tube so it fits the Ultrafire 1100mAh protected cell I’m using (Aspire cell in photo for size only) The tail switch provides a lockout so the light can be safely carried or put in a backpack etc.
Although they’re CW, there’s no overly noticeable blue in either of the ones I got, they look nearly pure white to me.
Here’s some more info on it:
The light is sold nearly everywhere under MANY different brands. Ebay, Amazon, Aliexpress, Gearbest, Fasttech, etc. etc.
The one I got from Amazon (HOVINSO) has a tint noticeably more towards neutral than the one from Gearbest.
(probably just got a winning ticket in the Lettuce Bright tint lottery)
Gearbest has two brands of this, a no-brand (one I got) and an HKV brand.
The Good:
- It’s very bright
- Tint is not too cold 5000-6000K
- Switch extremely easy to find in the dark (big protruding red bezel ring) :+1:
- Switch is very effortless to click, feels nice, a real joy to use!.
- Always starts on High :+1:
- Simple UI: Single click ON – click again OFF :+1:
- Hidden strobe - double click :+1:
- Ramping UI - 4 seconds from H to L flashes twice at lowest and at highest. :+1:
- Well defined hotspot, deep reflector has decent throw
- Springs on both ends inside fits about any 18650 battery I tried
- USB charging cover fits flush and snug
- Glass lens
The Bad:
- Switch can accidentally switch on fairly easy.
- No way to lock-out, no mechanical lockout (non-anodized tail threads)
- Because of these two cons I don’t recommend for pack or carry around, makes an EXCELLENT home utility light though.
I don’t really like mode memory and for certain uses (like this) I like lights that always start on high.
I haven’t used the USB charging but I took a measurement using Barkuti’s method (between the driver’s spring and retaining ring)…
I’m getting 4.32v (HOVINSO brand from Amazon)
Can’t measure the No Name one from Gearbest ATM, since it’s at my mother’s house as a home utility light. I’ll check it soon an post my findings.
Links:
The one I got from Amazon the description shows H > SOS but is actually ramping with double click strobe (description also shows zooming but it’s not).
The one I got from Gearbest (un-branded) 5000-6000K:
https://www.gearbest.com/led-flashlights/pp_604347.html
Here’s the other one at Gearbest (HKV brand) CW 6000-6500K:
https://www.gearbest.com/led-flashlights/pp_1295273.html
Fasttech also has it (Innuo branded):
https://www.fasttech.com/product/9634574
Bangood has a somewhat similar zooming version, also stepless dimming (XANES brand, only $6.89!):
Zooming versions also sold everywhere under MANY different brands
