This is my first real mod and review so forgive my ramblings. Ive always mucked around with different interests and this is a new learning curve for me that I dont believe has finished here.
To start of I ordered this 3 amp 3 mode driver, high medium and low with memory which the original driver did not have from IOS.
I had to machine the pill out for this driver to fit. On testing the torch it was extremely bright. With the stock driver there was no real heat build up with extended running on high. After running this driver on high for 45 minutes the temperature on the outside of the torch settled on 47 degrees celsius. A big difference from the stock driver. On a couple of walks down bush tracks the torch was a big improvement in light output.
The cost then blew out on this mod. On getting up one night with the light on low the light went really dim. The led barely glowing. Bugger. Cutter not being far away, I got a couple of 2S tint XML led's of them as they did not have 3C tint in stock. I believe this turned out to be a stroke of luck as i will explain later. To cut a long story short, these 2 leds went the same way. If anyone has an explanation I'm only to happy to hear.
What to do next. I dont think that I damaged the driver installing it and it is supposed to have temperature protection. I got another three leds of the same tint, again from cutter (unbelievable good service from Matt in the front office. I reinstalled the stock driver and the torch ran like a charm so maybe I did damage the driver some how? I ordered another driver the same and another 3 mode 3 amp driver of lightmalls. The IOS driver turned up first so I bit the bullet and installed it hoping not to repeat the past.
While I was at it I soldered a button onto the positve contact part of the driver as this torch will not take protected batteries and the King Kongs I have are flush on the positive end.
Added this anti refective lens
With a little bit of intrepidation the batteries were installed and the switch depressed. I was a little happy when there was a bright light to say the least. I have been running it no problems for a few days now without problems. With 2 cells installed current draw is 1.5 amps on high, medium .5amp and low .12 amps. the memory works perfect and the switch only needs the lightest touch to change modes.
The following beam shot is a 504B with MF Ultrafire 3 mode 3 amp XML T6 drop in which incidently does run 3 amp on MF Trustfire 2400 on the left and XML U2 2S 3 amp driven JM05 on the right. Its a bit hard to tell but the Ultrafire drop in is an extremely bright white light. The JM05 on the other hand has a very neutral tint giving a realistic color to whatever you are looking at.
The last shot is pretty much what you get, maybe not quiet as bright as in real life. The colors in the photo are what you see. I love it. The tree in the background is 120 meters away on Google Earth.
Thanks for reading.
I
